![]() Join Date: Feb 2009
How much to shorten drive shaft?
What should I pay to shorten drive shaft (in california)? My last one on my 65 was $250. Was a 2 piece shaft, u-joint in middle and one on each end. Used old u-joints, I supplied new yoke. Seemed pretty high, maybe I am out of touch?
Re: How much to shorten drive shaft?
I would think about 75 to 125 bucks. I know i can get one made for about 250.
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
Yes, but as you know physics are different in California, and the mass of the drive shaft is more, so it is thicker steel, so it takes more rod and more electricity to weld it...Oh, wait, thats actually Jupiter, not California....Ok, so I dont know why exactly I pay more here in California. I think it has something to do with getting screwed....
And you didn't get new joints for $250. For $50 more they should have nickle plated a dash plaque and give you a kiss too. Sounds a little extreme. On ebay in the past years there was a guy in Ca. custom making shafts and shipping them for $175-$225 balanced but they were one piece shafts but he supplied new yolk and all for that price. That may not be out of line price wise though. A few members on the board do that kinda work. Let them chime in on the cost.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
![]() Join Date: Aug 2010
I paid $230 at Inland Driveline in Ontario, CA, but that was a 1 piece with all new U-joints and a new slip yolk.
67 5.3L Build |
1969 Custom 30 wrecker
I had a machine shop cut 3" out of one for my stepside about 10 years ago for a whopping $30 dollars.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
#7 | |
the boat guy
65 for a 1 piece or 95 for a 2 piece is what we charge for a shorten and BALLANCE! No ujoints, no carrier bearing, no yokes, if it is a 2 piece we will check the center stub, bolt on yoke, and carrier bearing. I don't know what our 2 shops in california charge but I cant imagine much of a difference.
theirs no way I'd ever install a driveshaft that wasn't properly ballanced. You can if you wish, it does make it cheaper in the short run. If you don't ballance both pieces of a 2 piece driveline together as an assembly they are not ballanced.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
