Turn signal lights help
Hey gang
I can't get my turn signal lights in the dash to work. I've replaced the circuit board, new bulbs and holders but no indicator lights . All the others lights work and the turn signals do work. Any thoughts? Thanks Posted via Mobile Device
1972 GMC Sierra LWB (Aquafresh) 1962 Cadillac Convertible 1962 Cadillac Sedan project |
Re: Turn signal lights help
These diagrams are circulating on this forum so I'll pass them onto you. A quick check shows that they are the dark blue and light blue wires to the cluster from the turn signal switch and in turn get power from the fuse box( flasher). Get a test light and see if you get a flashing at cluster connection and work your way back. if you are more electrically inclined you can ohm the whole circuit see see where you are losing connection.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! Last edited by BMERDOC; 06-29-2011 at 12:17 AM. |
