Old 06-29-2011, 01:19 AM   #1
Gribbs
Gribbs's Avatar
Filling mirror holes in doors
Whats the best way to fill nasty holes in doors after removing big camper mirrors? I havent bought a project truck just yet, and I have noticed this will be one of many things to tackle. thanks! gribbs
Gribbs is offline   Reply With Quote
Old 06-29-2011, 01:24 AM   #2
TrkEnvy
Re: Filling mirror holes in doors
For small holes just quick shots with the wire feed. Grind em down with a flapper disc and maybe a thin THIN coat of body filler or 2K primer to smooth it out. Big holes, get some sheet metal. Use a bench grinder and some vise grips to shape a piece around the size of the hole and use a refrigerator magnet to hold it while you tack one side then remove magnet and tack other side.
TrkEnvy is offline   Reply With Quote
Old 06-29-2011, 01:46 AM   #3
EOChev
EOChev's Avatar
i found when you can reach the hole and hold a piece of copper behind the hole it helps out a lot
EOChev is offline   Reply With Quote
Old 06-29-2011, 02:14 AM   #4
Derek71784
If you don't have quick access to a wire welder or wanna go a little old school, I just filled some in my doors with "Eastwood's Lead-free Solder". All you need is the flux, solder, and a small butane torch. Grinds a little easier than a welder, and holds up nearly as well.
1969 C/10 SWB- Built 350/TH400/12-Bolt (Under Construction)
-Amateurs practice till they get it right, professionals practice till they get it wrong-
Derek71784 is offline   Reply With Quote
Old 06-29-2011, 08:46 AM   #5
cdowns
cdowns's Avatar
if welding up door holes you need to protect the glass or you'll b gettin new glass
Old 06-29-2011, 09:39 AM   #6
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
If they are the huge holes like what was on my truck, I made some small round blanks out of my old tranny hump. I tacked a small wire in the center to give me something to hold on to, then I just tacked it in place. Take your time are really move around the metal with the welder so you don't overheat and warp the metal.
prostreetC-10 is offline   Reply With Quote
Old 06-29-2011, 02:04 PM   #7
bigsnookmaster
bigsnookmaster's Avatar
x-2
bigsnookmaster is offline   Reply With Quote
Old 06-29-2011, 03:32 PM   #8
Grimpala
Grimpala's Avatar
If you ask some of our P.O.'s they'll tell you that duct tape and bondo is great for filling sheet metal holes.
Grimpala is offline   Reply With Quote
Old 06-29-2011, 05:44 PM   #9
longhorn70gmc
longhorn70gmc's Avatar
Hello Dereck, I have a craftman bottle torch, so if I use this as the heating element then the soder/flux will melt ok just like a soder iron does? Would I apply flux to the tip of the solder being used just like I was sodering wires or using a soder iron? I am asking just to make sure I do it right if I attempt this. Thanks for your educating feedback.
R/
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 06-30-2011, 12:05 AM   #10
Gribbs
Gribbs's Avatar
Thanks for all the feedback guys! As my first post, I am pretty stoked to become part of the community, once I buy a truck of my own. Looks like others are already learning from your advice too, so that's rad!
In the past I have worked on bikes, this one being my crowning achievement, which I could not have done without the help of a good friend of mine, Pozz
I found a 70' Blazer locally, but its $8500 (imported from texas i believe) and needs a lot of work. Sucks bein from rusty Canada! But once I find a good project, I will be set. Keep up the great help!!!!
Old 06-30-2011, 08:04 AM   #11
Before wire feed I would braze holes shut.
Old 06-30-2011, 03:53 PM   #12
Derek71784
R/
You'll just sand around the hole till it's metal for a good area around it, apply the flux to the metal and heat it until it tins over. Once it does this you wipe it off with a towel (use gloves, as you can imagine it's a little hot). Now that the surface is tinned and ready for solder you just heat and solder just like you would pipe... use less heat as you're closer to being done so you dont melt the existing solder out of the hole. I did this to mine about 2-3mo ago and it worked great. Once you sand it down it just looks like the same piece of metal.
Old 06-30-2011, 04:12 PM   #13
Derek71784
Next week I may do the holes in my roof. If so I'll try to do some step by step photos and start a thread with them to clear up any of the confusion on the steps. It's pretty simple and by the time you get the first hole or two down it's pretty simple.
Old 07-02-2011, 09:10 PM   #14
Gribbs
Gribbs's Avatar
that could really help!
Old 07-02-2011, 10:10 PM   #15
Daves70
Daves70's Avatar
Just outside of Oshawa in Courtice is Bill's Truck Shop.Bill usually has California project trucks coming and going.Try him.I have a 70 long bed that I could be talked out of,It needs a motor and cab mounts.But I will never get rid of my 67 short step.I have been hovering around here for a couple of years but I finally registered.You will find that these trucks are still around but solid sheetmetal is pricey up here.Good luck.
Daves70 is offline   Reply With Quote
Old 07-02-2011, 11:31 PM   #16
magicoolbus
magicoolbus's Avatar
I filled in some holes in the roof of my burb from a roof rack by duct taping a penny to the underside and using my millermatic 140. Flapper disk, spot putty, primed and paint.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 07-02-2011, 11:35 PM   #17
Gribbs
Gribbs's Avatar
I was at Bill's just last week. Problem is, I grew up in Niagara Falls and am pretty knowledgeable with border dealings, and I know I can import my own truck for a lesser cost. His trucks are solid, but many still need sheetmetal fixes and lots of work. We'll see, it's finding time to import a vehicle that is the biggest hurdle, as it is not very complicated at all.
Old 07-05-2011, 02:08 PM   #18
Derek71784
R/
Here you guys go, I finally did part of the roof just to show you guys how easily it can be done. I taught myself (I've done autobody for sometime just never toyed with solder till here lately) Check out my thread:
http://67-72chevytrucks.com/vboard/s...=1#post4772749
Old 11-18-2016, 11:54 PM   #19
cparr
cparr's Avatar
Here are mine. Just puddle weld it. Worked out great
cparr is offline   Reply With Quote
Old 11-19-2016, 08:05 AM   #20
GR8-68
GR8-68's Avatar
nail heads work well also plus it gives you something to hold then cut the shank off and grind smooth
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
