![]() Join Date: Apr 2011
Vin Plate
I am trying to decode the data plate on my left door jam, I am interested in paint, int, rear end ratios etc.
the Vin I get, but below it is a series of codes: Vin: CS147Z157124 Below: BID DD C 67 136 (the DD is smaller characters and placed a 1/2 line up from the other characters. Thx, Mike |
its all about the +6 inches
Re: Vin Plate
you won't get paint, rear end ratios, bed type... not even engine size.
C 2 wheel drive S inline 6 motor 1 1/2 ton 4 Cab with bed 7 1967 Z Built in freemont Cali 157124 is the 57124th truck off that line at that plant. |
Re: Vin Plate
Thanks, I had translated the VIN.
Do you know if the truck would have come with PS and PB? |
Re: Vin Plate
sorry, misread the original post.
Inlines with power steering and brakes are hard to come by, the older, the harder. a 67 with an inline os most likely not optioned with those, but that is just a odds comment, not a specific to your truck comment. |
Re: Vin Plate
I thought as much, when I bought the truck it had a 283 with a 350 behind it, a camero steering column (thus the power steering) and power brakes.
The brakes are very grabby, will almost throw you thru the windshield!! I am thinking about taking the power brakes off or maybe there is a way to reduce the boost?? |
Re: Vin Plate
I would start with inspecting the brake condition. Out of adjustment (too loose) of shoe adjustment will do that, as will wet shoes (leaking brakes or axle seals).
