fuel problem
quick problem guys & thanks in advance.
just installed new fuel pump, ignition module and MAP sensor, truck running great. then behold, died while driving, and now fuel pump is (i think) not getting power or signal. NOt priming, can not hear, no fuel in carb. Is there a easy way to test pump w/o dropping tank? |
Re: fuel problem
im guessing with a prob light u could power into the wire and see what happens? it would give you an idea if it is the pump or something else
86 C10- slight drop - cad425/bop400 - 2.73 - |
Re: fuel problem
Just a final update, after checking everything from front to back, all connections and grounds, low and beyold, the new fuel pump i had put in ealier, has failed!
so exchange and running now, thanks for all the help and suggestions, its appreciated. |
| Bookmarks |
