06-29-2011, 02:07 PM | #1 |
Grille question>????
If I am running a 69-70 front end will aa 71-72 grille still fit correctly? The grille that i want says it only fits 71-72 so i am trying to see if i can still use it. Any advice would be greatly appreciated.
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 Last edited by late68; 06-29-2011 at 02:07 PM. Reason: wrong insert |
06-29-2011, 04:42 PM | #2 |
Re: Grille question>????
not to sure. i just put a new grille on my 72. when i was looking through the magazines just for kicks and gigles they used the same part number for the mounting brackets so i would assume so. i dont blame you there is a huge price difrence in the two grilles that is what made me look at the mounting brackets for the difrent years.
Mark 1968 C-10 SWB 307/munci 4spd/411possi 1986-1990 1972 Cheyenne-10 LWB 350/TH350 IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER U. S. Navy Seabee "CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard" |
06-29-2011, 04:44 PM | #3 |
sorry forgot to say dont forget the running/blinkers for a 71/72 are in the bumper not the grille
06-29-2011, 05:07 PM | #4 |
10-4. Yea I found another thread that says it does work just have to use the 72 bumper for blinkers/ or mount them behind the grille.
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
06-29-2011, 06:41 PM | #5 |
Try spinnin 4 rear tars
A '71-72 outer will bolt up to the '69-70 fenders. I currently have a '71 outer billit inner on my '70. Hit a deer and couldn't afford a replacement 69-70 grill set for it at the time
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
