"the other guy"
which is the right tap?
im going to drill and tap my vortec heads to accept the stock temp sender. what is the correct tap needed?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: which is the right tap?
1/2 npt
If you want to do it properly,try to get a tapered reamer for the hole you drill,as it will make for a lot nicer job.
