06-29-2011, 07:32 PM | #1 |
My 1977 GMC Crew Cab Short Bed Cummins Diesel Build
I have meant to do a post about this for a long time. The truck is finally getting close to paint so I figured I better get my act together and get some pictures posted.
The Vehicle: 1977 GMC Sierra Classic Crew Cab Mods: Shortened Frame 1/2 Ton Conversion Intercooled Cummins 4Bt 4L80E Transmission Compushift computer and Monitor AutoMeter Black face ELECTRIC speedometer and tachometer 4 full power doors Shaved tailgate handle with Jimmy Blazer insert Factory Lowback buckets and console(plan on some newer seats done lowback that have a recline) US Indy Slots 15x7 fronts, 15x10 rears(These were on my Dad's 72 Chevy when I was growing up and figured it would be a good tribute for all of the help he provided me in building this. Gas door bed(I needed locking gas caps and my year bed just didn't look right with them) New cab mounts Future plans: I am in the process of painting it. With any luck it should be done in a couple of weeks. Once that is done I will have the whole interior redone. This truck has really been a labor of love. I knew exactly how I wanted to build this long before I owned it. I had the motor even before I got the truck! Even though I have done most of the work on this myself, none of this would have been possible without the knowledge my dad gave me as a kid, all of his help in the initial build and the kindness of my friend at Black Crow Customs for allowing me the use of shop space to do my body/paint work! |
06-29-2011, 07:33 PM | #2 |
Re: My 1977 GMC Crew Cab Short Bed Cummins Diesel Build
More pictures:
06-29-2011, 07:36 PM | #3 |
The blue and white frame was the donor truck for the suspension and the first bed. The bed was really just to rough as it had rust in the floor and only a single tank. Who ever said a diesel couldn't do a burnout!
07-01-2011, 06:17 PM | #4 |
I will try and get some more pictures posted in the next few days with any luck.
07-01-2011, 06:52 PM | #5 |
What Hump?
Where in phoenix are you located? There is a place over on 51 Ave and Bethany Home Rd that seems to have done a couple of similar modifications shortening the frame like your doing.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
07-01-2011, 09:20 PM | #6 |
I am at 35th Ave and Bell Rd. I know of about 7 trucks done by that place at Bethany but mine was not one of them. There is a white 4x4 in my neighborhood that they did though. Last I knew the owner of that shop was driving around a yellow short bed stepside he had modified.
07-02-2011, 12:44 AM | #7 |
that's cool nice work
07-03-2011, 05:06 PM | #8 |
Resident of Here
Yay! A build for it!
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
07-03-2011, 08:01 PM | #9 |
Man, a 4BT is originally what I wanted to go with on my build too!!!! Gonna be a sweet ride - GMC too, I love it!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
08-08-2011, 09:10 PM | #10 |
6>8 Plugless........
Sweet build man! Anymore updates on it?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-22-2012, 01:22 AM | #11 |
Updates???
How much HP and Tq does that 4BT put out? Posted via Mobile Device
CHEVY ONLY |
02-22-2012, 11:10 AM | #12 | |
As far as mechanical goes, I have purchased a new torque converter as the reman one was junk. I have also powder coated another set of A arms and had new bushings and ball joints installed. The whole truck is coming along. It just takees a ton of time! Here are some pretty detailed specs from a Cummins Website: The Cummins 4bt is essentially a 5.9L 12v Cummins with 2 cylinders removed. This 3.9L, 4 cylinder, inline diesel was commonly used in commercial van applications. Generous amounts of torque in a small package make the 4bt common for engine swaps in Jeeps & small trucks/suvs. Cummins 4BT Specifications: Engine Name: Cummins B3.9L/4BT Applications: Chevrolet Step Vans, Commercial applications Configuration: Inline 4-cylinder diesel Displacement: 3.9L, 239 cubic inches Bore: 4.02 inches Stroke: 4.72 inches Compression Ratio: 17.5:1 Aspiration: Turbocharged, non-intercooled Engine Weight: 745 - 782 lbs Oil Capacity: 10 quarts Horsepower: 105 hp @ 2,300 RPM * Torque: 265 lb-ft @ 1,600 RPM * GVWR: 16,000 lbs *Common rating, though horsepower & torque ratings may vary by application. Cummins 4BT Dimensions: Length: 30.6 inches Width: 24.6 inches Height: 37.7 inches |
02-22-2012, 11:11 AM | #13 | |
As far as mechanical goes, I have purchased a new torque converter as the reman one was junk. I have also powder coated another set of A arms and had new bushings and ball joints installed. The whole truck is coming along. It just takes a ton of time! Here are some pretty detailed specs from a Cummins Website: The Cummins 4bt is essentially a 5.9L 12v Cummins with 2 cylinders removed. This 3.9L, 4 cylinder, inline diesel was commonly used in commercial van applications. Generous amounts of torque in a small package make the 4bt common for engine swaps in Jeeps & small trucks/suvs. Cummins 4BT Specifications: Engine Name: Cummins B3.9L/4BT Applications: Chevrolet Step Vans, Commercial applications Configuration: Inline 4-cylinder diesel Displacement: 3.9L, 239 cubic inches Bore: 4.02 inches Stroke: 4.72 inches Compression Ratio: 17.5:1 Aspiration: Turbocharged, non-intercooled Engine Weight: 745 - 782 lbs Oil Capacity: 10 quarts Horsepower: 105 hp @ 2,300 RPM * Torque: 265 lb-ft @ 1,600 RPM * GVWR: 16,000 lbs *Common rating, though horsepower & torque ratings may vary by application. Cummins 4BT Dimensions: Length: 30.6 inches Width: 24.6 inches Height: 37.7 inches |
