66 c10 parts help
Im looking a source for the emergency brake cables, starting with the ones that start in the rear drum brakes all the way to the parking brake lever Help Pls Thanks Jeff
1961 crewcab
Re: 66 c10 parts help
I think you have to find them used.. and 66 is all by itself... chev and gmc '66 only...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Senior Enthusiast
Classic Parts shows listings for the 1966. They list 2 different intermediate cables - depending on wheelbase. I don’t own a 66, so I can’t confirm the fit:
http://www.classicparts.com/1966-68-...ctinfo/71-751/ http://www.classicparts.com/1966-72-...ctinfo/71-761/ http://www.classicparts.com/1966-72-...ctinfo/71-762/ http://www.classicparts.com/1966-72-...ctinfo/71-771/ |
![]() Join Date: Mar 2010
i made part of my cables i bought cable the same size as whats on the truck then drilled out some round stock and welded the end of the cable to the round stock
Grandpa in the rustmobile...
i got some calbes that come out of the drums from a 68 pm me if interestd
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
got mine from inline tube,excellent quality!every exact fit part you need.you can get just individual parts or the whole kit.i went with the stainless kit.love it!
sorry,couldn't edit my last post.complete kit front to back in stainless was $185.hope this helps.dan
I think I bought 1 rear cable that attached to the backing plate from NAPA might check there....Kieth It did look different but it worked (all rubber instead of metal covered.....
i bought some for a 1966 chevy truck from classic parts,but it was back in 1988 when they were known as chevy duty.they probably do still carry them.jonzcustomshop is right the 1966 are all to theirselves.1964 and 1965 are different.
