Old 06-30-2011, 02:04 PM   #1
truckster
truckster's Avatar
Buick Quadrajet on a SBC 350?
Will a Buick Quadrajet (front inlet) work on a Chevy 350 with a stock intake?
truckster is offline   Reply With Quote
Old 06-30-2011, 02:12 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Buick Quadrajet on a SBC 350?
If it is a Q-Jet (spread-bore) intake, it's a direct bolt-on. If it isn't a spread bore, you'll need an adapter that will allow it to be bolted-on. I'm not a fan of those adapters, but I'm sure there are plenty who are.
Member Nr. 2770
Old 06-30-2011, 02:15 PM   #3
truckster
truckster's Avatar
It's a factory Q-jet, it just has the front inlet that Buick put on them.
Old 06-30-2011, 02:19 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
What's the problem? I don't see one.
Member Nr. 2770
Old 06-30-2011, 02:20 PM   #5
truckster
truckster's Avatar
I didn't either. Someone told me it would hit the water outlet, but I can't see any way it would reach that far forward.
Old 06-30-2011, 02:35 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
q jet on my truck had the inlet for fuel in the front too
John
1999 Toyota Tacoma 4x4
Old 06-30-2011, 02:45 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
NAPA should have an "ell" fitting that will turn the corner and put it where you want it to be.....if you need one.
Member Nr. 2770
Old 06-30-2011, 06:08 PM   #8
nbrfd007
nbrfd007's Avatar
No problem, ran one off a 68 skylark on my 71 Jimmy for years.
nbrfd007 is offline   Reply With Quote
Old 06-30-2011, 08:21 PM   #9
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
I made a custom steel line from the fuel pump to the front inlet of the Buick Q-jet I am running. No clearance issues with the thermostat housing.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
