Old 06-30-2011, 02:48 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
quick HEI wire ?'s
My HEI dizzy is wired to the red wire (cant remember wich) I was reading somewere that it should be wired STRAIGHT to the fusebox?
Am i missing out on driveability/performance here? If I should rewire it, what guage of wire? Thanks
John
1999 Toyota Tacoma 4x4
Old 06-30-2011, 02:54 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: quick HEI wire ?'s
I'm thinking that will work fine. It should be the switched connector from the Ignition switch. (if that makes any sense)..
Lockdoc
Leon
Old 06-30-2011, 03:16 PM   #3
FLDBRED
Year One sells the proper wire with the right connections on each side,the fuse box juction side is a spade terminal.It makes the HEI swap clean and easy!
FLDBRED is offline   Reply With Quote
Old 06-30-2011, 04:05 PM   #4
oldblue1968chevy
I was reading somewere that it needs to be ran STRAIGHT to the fusebox etc I dunno where this wire goes on the other side, just thought id ask the forum
John
Old 06-30-2011, 05:07 PM   #5
FLDBRED
That box is the other side of your fuse box,you are ok! The part # for the Year One wire is LOO510 =$9.20, the tach feed line is LOO515. If your hook up is direct with no splicing then you don't need them!
