Old 06-30-2011, 08:10 PM   #1
souza777
souza777's Avatar
Unhappy Flex plate - tranny bolts- need help!?!?
need some help?? what are some of the ways you guys have changed out a flex plate? what is the best way to get to the upper tranny bolts- engine bolts?
I have a 1976 LB 3/4 ton truck?
souza777 is offline   Reply With Quote
Old 06-30-2011, 08:36 PM   #2
rwhit57
rwhit57's Avatar
Re: Flex plate - tranny bolts- need help!?!?
You have to pull the trans.and starter. There are 3 bolts from the torque conv. to flexplate I usually use a long ext on the upper bolts to the motor, don't forget to block up the motor. Get some help if you don't have a trans jack.
rwhit57 is offline   Reply With Quote
Old 06-30-2011, 09:01 PM   #3
donut
donut's Avatar
Couple of extensions and swivels. I did mine like this and was to lazy to pull the bolt down "hump"
I used a couple of jacks (iirc) one under the oil pan, one under the tranny pan. (blocking as needed so you don't crush the pans.) and a couple pieces of scrap all-thread to keep the trans lined up (correct size rod) I was able to slide the trans back far enough to get the old flexplate out and a new one in.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 06-30-2011, 10:37 PM   #4
78 Chevyrado
I have some swivels and a 4 ft. extension I use to get the upper trans/engine bolts. the longer, the better. Try to use the ball-socket type of swivels instead of the u-joint kind, they're a little easier once its too far in for your hands to reach. If that fails, I've gotten the 2 top bolts from above leaning over with my head by the distributor.
78 Chevyrado is offline   Reply With Quote
Old 07-01-2011, 04:17 AM   #5
souza777
souza777's Avatar
should those two upper the same size bolt as the other four?
Old 07-01-2011, 07:11 AM   #6
xrcr
yep
xrcr is offline   Reply With Quote
