06-30-2011, 08:37 PM | #1 |
Antifreeze leak
My 87 classic has developed a leak. Being new to this mechanic thing I thought the lower hose was the problem as it was running off it to the ground when the vehicle shutter off...However it is coming from behind where the hose is clamped on at the engine...any suggestions? Expensive fix as I probably won't be able to do it myself.
Posted via Mobile Device |
06-30-2011, 08:46 PM | #2 |
Re: Antifreeze leak
Do a little poking around. My first guess, the water pump. (leaking out the "weep" hole at the bottom) Could be something as simple as the hose is leaking where it attaches to the pump. Price wise, don't know as I've done my own since before your truck was new.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
06-30-2011, 09:52 PM | #3 |
God is good!
Re: Antifreeze leak
I agree, it sounds like the water pump is ready to give out. Get under the truck with a flash light and point it right under the water pump. There's a little hole underneath that leaks a little to warn you. The fix is very easy. If you're new to this, just buy a Haynes or Chiltons manual and go for it. Don't know how your market works, but I'd imagine anyone would charge you maybe 1 hour's worth of labor do replace it.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
06-30-2011, 10:06 PM | #4 |
Re: Antifreeze leak
It is fairly easy to replace the water pump that would be a great project for someone with very little mechanical experiance. You have to have a car guy friend that would be willing to lend a hand to help a buddy out. It is always good to make friends with someone with a lot of tools. Jim
06-30-2011, 11:01 PM | #5 |
Re: Antifreeze leak
While I have got this answer pretty easy... Let me ask this....same truck....the battery gauge is going all the way up when I am stepping on the gas and the lights are all getting very bright then dim down as I let off the gas and the gauge goes down to normal (half way).... Any suggestions on this problem?
06-30-2011, 11:04 PM | #6 | |
Re: Antifreeze leak
07-01-2011, 08:00 AM | #7 | |
Re: Antifreeze leak
07-01-2011, 02:07 PM | #8 | |
Moderator
Re: Antifreeze leak
07-02-2011, 11:04 AM | #9 |
Re: Antifreeze leak
Ok I have decided to do it myself. Should be fun...now which Chilton do you recommend I buy? The Chevy v8 Overhaul book or the one for Full Size GMC Trucks?
Thanks for the help! |
07-02-2011, 11:22 PM | #10 |
Chevys Kick A$$
Re: Antifreeze leak
Yep sounds like the water pump that's pretty easy one to do. The second problem with the gauges sounds like a bad alternator. With it doing what its doing I would pull it off and go down and get it tested at the store so you don't end up frying any parts. There should be repair manual that has your year of truck in it should be a complete repair one that's what I have always gotten
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
07-06-2011, 11:18 PM | #11 |
Re: Antifreeze leak
Ok i dont know that the Chilton is specific enough for this job. Trying to find a video how to...what years are going to be similar to my 5.7 87 sierra that I can look for?
Bill Thanks again! |
07-07-2011, 12:07 AM | #12 |
Re: Antifreeze leak
best case scenario...water pump. Just an FYI if you take the alternator down to the parts house to have it tested, have the cash to buy a new one, it will save you some gas money, because the internal regulator is toast.
79' GMC stepside...the money pit! 355 aluminum partoit heads 2.02,lunati 268 flat tappet,comp roller rockers 1.6,hi-tech torque link intake(Jim McFarland),electric water pump,650 holley double pumper,msd 6al,msd street fire dizzy,doug's long tube headers(ceramic),3" exhaust(flowmaster 40) |
07-07-2011, 07:24 AM | #13 |
78K & 79C Jimmys
Re: Antifreeze leak
how bad is the water pump
doesn't it (ALT)run off the same as the Water pump (looking at my 87 burb pics) may wana do the pump then tighten belt and check again one weep on top and another under it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 07-07-2011 at 07:36 AM. |
