07-01-2011, 01:30 AM | #1 |
Cargo Lite...3rd Brake lite w/o loosing Cargo Lite function?
I have been looking for a LED set up that would replace the cargo lite so ... that I have my cargo lite plus a 3rd brake lite. Who sells these? I did a search but most post were 3-4 years old. Thanks
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 07-01-2011 at 01:31 AM. |
07-01-2011, 01:59 AM | #2 |
Re: Cargo Lite...3rd Brake lite w/o loosing Cargo Lite function?
I got 2 frog eye type red LED's from PEP BOYS [the ones that you can try out while in the box] and double side taped them inside the light housing [perfect fit], drilled 1 small hole in the light housing [for the wires] and tapped into the brake switch. They don't effect the cargo light and you can't see any hint of red until the brake lights come on, very bright at night but a little on the dim side during the day,
07-01-2011, 02:52 PM | #3 |
You should post that in the Under $50 thread.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
07-01-2011, 05:45 PM | #4 |
Who's got steelies?
Got any daytime pics with it on/off?
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
07-01-2011, 06:35 PM | #5 |
Check out Longhorn Man's FAQ thread on the subject:
How to make your cargo light double as a 3rd brake light... and look bone stock
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
07-01-2011, 06:45 PM | #6 |
its all about the +6 inches
actually, don't bother with my FAQ... when I checkied it out in real world application... IE looked at it at night on the street, it sucked so bad I just chopped the wires.
07-01-2011, 10:37 PM | #7 |
ttt
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-02-2011, 02:21 AM | #8 |
I will try to get pics tomorrow.
07-02-2011, 09:38 AM | #9 |
I am looking for the LED set up not the bulbs...Drilling holes in the Circuit Rider is not an option
07-02-2011, 02:20 PM | #10 |
PROJECT 7DEUCE
The last time I saw those the boardmember was making them but noone has heard from him in awhile..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-02-2011, 02:31 PM | #11 | |
That's correct. Good memory
07-02-2011, 03:10 PM | #12 |
I'm also very interested in this. I have been looking for a after market one but I like this much more.
07-02-2011, 10:54 PM | #13 |
Ideas ??
07-03-2011, 09:33 AM | #14 |
I found a kit sold by Early Classic Enterprises http://earlyclassic.com/catalog.aspx?category=New+Items but the web site lists it as currently unavailable. Their shop is around the corner from were I work, I'm going to stop by after the 4th.
well that link does not take you directly to the part it's # is 04-3rd or L.E.D. Cargo Light & 3rd Brake Light LED Kits Last edited by Daddy Brim; 07-03-2011 at 09:38 AM. Reason: it needed more info |
07-03-2011, 09:53 AM | #15 | |
07-03-2011, 12:15 PM | #16 | |
07-03-2011, 01:25 PM | #17 |
I have a radical idea!
C'mon man! Your truck is too cool for a 3rd brake light anyway! Leave that to these newer plastic toys trucks.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
07-03-2011, 02:23 PM | #18 | |
07-05-2011, 08:40 PM | #19 |
I went by Early Classic Enterprises today and talked to them and they said that the vendor that they got the led kits from went out of business. I'm going to keep looking or find some leds that will work and modify it myself.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
07-05-2011, 09:13 PM | #20 | |
07-05-2011, 09:42 PM | #21 |
I used a `93 F**d Ranger third brake and cargo combination. I sanded it a little flatter on the sealing surface and being that it is a factory brake lite it is bright and the bulbs are easily found.
07-05-2011, 10:48 PM | #22 |
6>8 Plugless........
I think I'll try what cheyenne shortstep did and see how I like that. It seems like some one should make a few of these.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-05-2011, 11:48 PM | #23 |
OK here are the crappy pics I took. You can see the small hole I had to drill for the wires, if you don't want to drill your perfect original light housing you could do this mod to another housing and spare the OG from the drill. As you can see it does not interfere with the cargo light, I will take a pic of it in the daylight tomorrow. This was cheap & easy as it gets, adding a modern safety feature without distracting from the original classic look.
07-07-2011, 12:39 AM | #24 |
Wow, that lights up pretty good!
Btw, I bought one of those LED strips and mounted it on the rear cross sill below the tailgate. It lights up with the brakes pretty brightly...if you like that look. I think it looks just fine.
07-12-2011, 03:54 PM | #25 |
ECE Update...
I got an email from Mark and they are working with a new Vendor and thsy hope to have a new source for these Lights in about a month...though you all might like to know.
