![]() Join Date: Jul 2009
Turn signals not canceling
Left turn signal stays on after completing turn. Right turn signal cancels like it should after turn. All bulbs are good. I have never had the steering wheel off, Is there a spring in there that broke that is causing this? Its a 72 Blazer Thanks Jim
~Rest In Peace~
Re: Turn signals not canceling
possible the plastic clip broke off on the cancell switch inside of the steering hub .easy fix
is it a tilt wheel those are a little tricky to work on
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
No tilt column
20' Daredevil (Ret)
![]() Join Date: May 2003
There are little wire springs that cancel the turn signals, and when they break (the bent ends will snap off), the signals won't cancel. Left spring is a mirror image of the right spring. Hardest part is pulling off the steering wheel -- the springs are easy to replace. My local NAPA carries them, and I suppose any parts house does also.
EDIT: found a pic:
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 07-01-2011 at 10:24 AM. |
member #16
![]() Join Date: Dec 1999
Heres a pic of them installed.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
You guys are great with the pictures.... Thank you
Old Skool Club
![]() Join Date: Jun 2001
Some people will accidently break the cam by holding the turn signal lever while turning the wheel....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
My turn signal switch did the same thing, I sprayed a 1/8th can of silicone lube in the turn switch and after a little use mine started working.
toys'r'us
on day in the quiet down town i put on my right turn signal and the spring broke and completed the horn circuit!!! sooo embarassing
71 jimmy bone stock 350 sm465 33x12.5 rallies 79 caprice landau full load crate350 th350 lowered 20"wires 00 f150 reg cab sb 4x4 5.4L |
