Old 07-01-2011, 10:13 AM   #1
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
suburban rear axle
1991 suburban 350 tbi 700r4. I need a new rear axle. Whats a direct swap? I want the gears to stay the same.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-01-2011, 01:53 PM   #2
blakeduren
Re: suburban rear axle
You have a 8.5inch 10 bolt axle with 31 spline shafts.
You will have to find the gear ratio yourself.
You didn't mention 2wd or 4wd, but I assumed 1/2 ton because it has a a 700R4.
Get an axle from a 81-91 Sub, Blazer or 81-87 truck.
If you go older, you will get a 12 bolt, which has minor mods with the u-joint.
Axles older than 88 or so will have 28 splines...not a big deal if swaping the entire axle.
parking brake cables should work, if not, swap the entire brake backing plates.
blakeduren is offline   Reply With Quote
Old 07-01-2011, 06:39 PM   #3
rcbildr
rcbildr's Avatar
Can't assume it's only half ton. My 3/4ton diesel burb came with a 700R4.
Also I think 84 they changed the parking brake cable design. I had to do some mods when I swapped out the rear end on my 85 with one from an 82 Burb.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 07-02-2011, 11:31 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
You gotta figure out what it is by counting the teeth or if your lucky you might still have the build sheet for it in your truck. Which should have a code for your axle. If you want another 10 bolt or you could see about getting the 14bolt 6 lug the put in the light duty 3/4s tons. Late 80's to early 90's should all be the same.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
