07-01-2011, 12:06 PM | #1 |
toys'r'us
light fuse blows, where do i start?
on my 71, when i pull the headlight button out 1 click the 20a fuse blows and i lose the associated lights. where do i start? 2nd click and i have headlights, high beams, and signals, reverse lights.
71 jimmy bone stock 350 sm465 33x12.5 rallies 79 caprice landau full load crate350 th350 lowered 20"wires 00 f150 reg cab sb 4x4 5.4L |
07-01-2011, 12:22 PM | #2 |
Re: light fuse blows, where do i start?
a good place to start wood b by reading the board rules about double postings
07-01-2011, 06:50 PM | #3 |
its all about the +6 inches
look at the parking lights and the wires. If the harness has been hacked for a trailer plug, I'd start there.
07-01-2011, 10:28 PM | #4 |
Check the grounds.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
07-01-2011, 10:59 PM | #5 |
Have you done any work recently? Which 20A fuse blew? There are several easily acceible pics of the fuse box to help.
I'm still new to the details of these trucks but I'm growing stronger every day. Give us the details and some one here can help. Quick diagnosis for someone who doesnt know a lot about electricity is this. Unplug the taillamp harness at the firewall. Its inside the cab and just above the gas pedal. Pull the light switch to section one, fuse blown? No, Your problem is in the tail lamp section. You have just eliminated everything on the fuse as a source. Plug the taillamp harness back in and unplug at the taillamp connector at the back of the bed (on the left when lookin at the back of the cab just behind the bumper). Retest, blown fuse, yes? Check the taillamp harness for a short to ground. If you initially unpluguged the connector underneath the dash and it did pop, do this. Go to the front connector at the firewall (to the right of the M/C) and unscrew it to unplug it. Retest circuit, blown fuse, no. Check the front harness for bare wire. Its not long and will take minutes to check. If you have a buddy and a small collection of spare fuses you can shake the harnesses to check for the short to ground. These are quick directions for someone who can get around a truck. Again, if you supply more info I'm sure myself or another member would help you with a big smile. I love fixin things.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
07-01-2011, 11:23 PM | #6 |
I can't edit for some reason. I guess I edit too much and my right has been revoked for some reason.
07-02-2011, 02:28 AM | #7 | |
toys'r'us
bmerdoc, thanks ill crack a beer and try that in the morning
07-02-2011, 08:29 PM | #8 |
toys'r'us
Thanks longhorn man and bmerdoc. I unplugged the harness in the rear and there was no blow. I noticed some wires tucked away and they had bare ends. must have been from trailer wireing. Some black tape fixed it up.
Still no help from the electrical section
07-02-2011, 08:42 PM | #9 |
I'm glad we could help. I haven't been a member of a forum for a long time because of less than desireable members. I found you guys and have been extremely happy. I'll answer any question I think I may be able to help with. ENJOY THAT TRUCK!!!!
