Old 07-01-2011, 02:01 PM   #1
jgknowla1
Stalling out!
I hope someone knows what's going on with my truck. I've got an '82 C10 305/350.
Couple days ago while driving to work I noticed that the idle rpms were lower than normal at stoplights. On my way home that day, it even stalled at a light. Normal driving speeds are fine - it has fine acceleration, sounds normal, etc. So here's that info:
* When I idle, the RPMs drop slowly over the course of about a minute until it stalls.
* Choking it (manual choke) brings the RPMs back up and it idles fine.
* changed fuel filter - old one was clean inside
* changed plugs and wires
* adjusted idle screws on carb (qjet) to 2.5 turns out each
* looked for and couldn't find any vacuum leaks - tightened down carb to torque specs
* Carb was rebuilt about a year ago and has been working fine
Any ideas of where I should look? What could be doing this?
jgknowla1 is offline   Reply With Quote
Old 07-01-2011, 06:50 PM   #2
jgknowla1
Angry Re: Stalling out!
OK, I took the top off the Qjet this afternoon and cleaned it out. I also lowered the float a tiny bit since it seemed that fuel was soaking the top gasket.
I didn't see anything wrong with the carb. I put it all back together and it made no difference - still stalling out. RPMs still slowly drop in idle and then it stalls.
Anybody have any ideas?
Old 07-02-2011, 07:28 AM   #3
donut
donut's Avatar
Re: Stalling out!
Too lean?
How much choke "fixes" it? IMO, a little choke and you may be running a little to lean. Lot of choke and you may have a vacuum leak you can't find.
It may be something simple that you can't see yet. crud in passages could do this. Also a stumbling problem I had was fixed by cleaning out a tiny piece of gasket that was touching the metering rod/jet area and causing a lean condition.
How are you adjusting the idle mixture?
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 07-02-2011, 11:26 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Stalling out!
Yea I agree I am thinking its to lean or you got an unknown vacuum leak! Have you checked the fuel filter in your carb I am pretty sure it would have one?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 07-03-2011, 11:53 AM   #5
rayfinseats
Re: Stalling out!
Fuel pump? Vapor lock?
rayfinseats is offline   Reply With Quote
Old 07-05-2011, 08:29 AM   #6
jgknowla1
Re: Stalling out!
Hey thanks for all the replies - lean condition makes sense I think. This weekend I redid the timing and found that base timing was too far advanced by probably 8 or 10 degrees. So I set it back to what the decal says (8) and it's running and idling much better.
I don't know enough to understand why timing would make it seem like it's lean, but I guess if it's not burning the gas efficiently that it could look the same.
Anyway, I know I've got the throttle shaft vacuum leak that's so common on Qjets, and there may be more. So I'm sure vacuum leaks are contributing to the truck's tune, but I can't replace the carb just now.
The only way I know how to adjust the mixtures is with the little screws on the front of the carb. I'll drive it for a while and see if it still acts like it's lean.
Thanks guys!
Old 07-06-2011, 01:26 AM   #7
Stepper562
Stepper562's Avatar
Re: Stalling out!
Advanced timing means the truck runs faster in laimans terms, sucking in more air but same fuel amount. Gotta fatten it up a bit. Slow down the idle screw a bit and throw a little more fuel into it. See if that works. If not, vacuum leak it is. I'd check for the before anything. A lot cheaper then anything else. If not a vacuum leak, replace the carb.
Good luck, let us know how you make out for future members.
Stepper562 is offline   Reply With Quote
