Old 07-01-2011, 04:11 PM   #1
forestb
forestb's Avatar
gas tank and suspention
I have a 20 gallon gas tank, in my 62 C10 step side short bed, between the frame rails, behind the rear axle and am tiered of the height of the truck changing in the rear every time I fill it up. I think it changes by at least an inch. would it help if I put the tank in the bed behind the cab. Or does anybody have any ideas on how to fix this without affecting ride quality.
forestb is offline   Reply With Quote
Old 07-01-2011, 04:23 PM   #2
Brandonc20
Re: gas tank and suspention
new suspension....how old and what kind of suspension do you have?
Brandonc20 is offline   Reply With Quote
Old 07-01-2011, 04:39 PM   #3
forestb
forestb's Avatar
I have a sett of 4 inch drop coils from cpp that I bought about 8 years ago
Old 07-01-2011, 05:16 PM   #4
kieth
kieth's Avatar
bag it, cost $200.00 height adjustable good ride.......suicide doors....
kieth is offline   Reply With Quote
Old 07-01-2011, 08:20 PM   #5
Bears63
...just another truck junkie..
Bears63's Avatar
Moving the tank forward would make a difference as far as affecting ride height when full and empty. It would be more stabilized since it would be more in the center of the vehicle. Not only that, but when on the tail and full it makes the truck more butt heavy and that would be extra weight swinging around on tight corners.... Get where I'm going there? More towards the center and it would have little affect when full or empty.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 07-01-2011, 09:56 PM   #6
forestb
forestb's Avatar
So if I were to bag it that would mean I would have to set up some kind of system that would slowly add air to the bags as the gas tank slowly emptied. or are the compressors set up to add air when there is more wait added.
Old 07-01-2011, 11:07 PM   #7
badblu97
Double 6's
badblu97's Avatar
You could go with an accuair, and I think Airride tech has one, but accuair has an auto leveler. save your pennies!!
Street Glidin!
1966 LWB Custom Cab (sold)
1982 Short Fleet (under the knife)
1998 S10 2wd Fleet
2007 Chevy Silverado Crew
2007 Harley Davidson Street Glide
badblu97 is offline   Reply With Quote
Old 07-02-2011, 09:30 AM   #8
kieth
kieth's Avatar
The truck really need that weight in the rear, the biggest problem with a pickup is its lack of weight in the rear when it is not hauling anything. as to the leveling problem call me. I will find you a truck air ride valve that stays at the same height all the time. You would just have to have a air tank that has high pressure air in it, and when you fill the tank it would let more air in. As the tank empties it will lower the truck back to the correct height. Later you could add a compressor to the system which would keep the air tank topped off at a preset pressure. Kieth call me I do not sell them but I deal in over the road trucks and I could help you find the parts. 918-446-2245
Old 07-02-2011, 10:30 AM   #9
Brandonc20
not meaning to steal this thread or anything, but can you run bags with coils and shocks. my problem is that my C20 has c10 lowering sprigs and my suspension isnt the greatest. if so where would I mount these and where do I buy?
