Is Your Truck 506 Med. Blue?
I'd like to see it. My truck has the paint code 4506aa in the SPID. The chips just don't cut it. I wanna see it on the truck. A 67 S/B Fleet would be a plus!!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
Re: Is Your Truck 506 Med. Blue?
I'll play. Mine has been repainted, but it appears to be original. Build sheet says 506.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
Thank you!! Look like the color the PO didn't spray over in the bed. Is yours metallic?
Grandpa in the rustmobile...
Mine used to be...its repainted some baby blue, the interior is still the medium blue though...Its going back that color oneday if it ever gets painted...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#6 | |
Yes, the PO had painted it a really nasty looking bright blue at one time. The repaint was decent, though since it appears to have been some time ago and has some scratches to prove it. Can't complain for a $650 Truck. It had a canopy on it when I bought it, so my guess is that they painted it with the canopy still on it since the tops of the bed rails and inside the bed are still the puke blue. Some day I will probably get some Hot Rod Flatz and paint those (color looks similar).
I know this is old but bump to the top i would like to see some 506 med blue metallic trucks interior or exterior!
Glove box lid code for it should be 04537AD and hear the one GM used them selfs WE5146. Hear a web site for paint codes and colors from 1917 too 2013 and has some custom stuffel also. www.paintref.com/paintref/index.shtml
bump
Like this? Interior is going to depend on year and trim color.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
How many 67 blue interior colors were there?
Posted via Mobile Device |
A '67 would have two shades of blue paint on the interior plus the argent color for the glove box door. I went into this in detail on another post for a 507 two-tone truck. The colors and color chart are the same for a 506 truck. Now in the end Mr Chevrolet ended up painting his truck interior other than factory interior colors but it still "looks right". In support of my information 67c10rustbuket was kind enough to provide some pictures of his disassembled truck showing the original interior blue ploy and the darker blue used on top of the dash. The blue poly is the correct color, use Ditzler 13391 color and is correct for the 506,507 or 508 base color trucks. I have done a lot of color research and will on occasion do a break down for someone like I did for JHT67 http://67-72chevytrucks.com/vboard/s...=511283&page=2 post #30. If you need more let me know.
