Old 07-01-2011, 07:39 PM   #1
100%Chevy
351 V/6-I found a loose part in the oilpan!
If my pictures show up, maybe someone can tell me what or where this part came from!
Click for larger image.
I pulled the pan the fix a big dent in the bottom and this was in the sludge in the bottom!
Sure would like to know what it is!
TIA,Mike.
100%Chevy is offline   Reply With Quote
Old 07-01-2011, 10:59 PM   #2
Max1775
Max1775's Avatar
Re: 351 V/6-I found a loose part in the oilpan!
Crazy, but it looks like the tip off of a cutting torch.
Max1775 is offline   Reply With Quote
Old 07-01-2011, 11:03 PM   #3
100%Chevy
It's solid steel,1" long and 1/4" in diameter.The big end is about 5/16".
I don't know this engine very well and was hoping someone who does could help me figure this out.
Thanks,Mike.
Old 07-01-2011, 11:16 PM   #4
71swb4x4
71swb4x4's Avatar
Does it hold the dipstick tube in place?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-01-2011, 11:29 PM   #5
Max1775
Max1775's Avatar
That is just odd. I can't think of what that could be. Is it possible that it is not an engine component?
Old 07-02-2011, 05:20 PM   #6
mikie 1954
I would try the 6066 GMC message bourd and see if any one there knows.
mikie 1954 is offline   Reply With Quote
Old 07-02-2011, 05:47 PM   #7
padresag
well it doesn't look like it is a piston or camshaft and of course the pictures are not that great. motor still turns over I take it
ron
padresag is offline   Reply With Quote
Old 07-02-2011, 09:27 PM   #8
100%Chevy
Thanks guys.
I am trying Jolley's site-Still waiting for answers.
I ran it 2 weeks ago.
I have it apart for painting.I took the oil pan off to fix some dents when I found the part.
It may be part of one of the in head pcvs.Not sure though.
Mike.
Old 07-02-2011, 10:15 PM   #9
100%Chevy
O.K.,it is part of the in-head pcv.
With the help of a fellow named Lewis on Jolley's site,it's been determined that it fell apart at some time and was replaced with an"AC" replacement.
Someone just never bothered to pull the pan and remove the old part!
Same part used on all GMC,V/6's,so if you have one,check them once in a while.I was told they are prone to come apart.
Thanks for all the suggestions and help!
Mike.
Old 07-03-2011, 12:38 AM   #10
Max1775
Max1775's Avatar
LOL, good info!
