Pinion Angle on one piece drive shaft
I bought a new set axle saddle from ECE, to install on my newer 12 bolt that has 5 bolt pattern and larger brakes. My question being what should the pinion angle be on the rear. My truck is lowered with a 6in spring in the rear and has a one piece drive shaft. With the truck on a flat surface my trans has a 4 degree angle. Should I put the rear at the same 4 degree angle. This is what the guys at ECE said to do, are they right. This sounds strange. I have a trailing arm rear. Please help. Would like some input.
Thanks ![]()
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect. |
at ride height what ever the angle of the tranny is, is the angle you want the rear end, this way it cancels out and keeps the u joint turning.
So What they told me is correct? Anyone.
The pinion angle should be the same as the angle of the engine/transmission.
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
Go to this website to read about setting proper pinion angles. http://www.4x4wire.com/tech/pinionangle/
'72 C/10 LWB 402/400 Blaine, MN |
