07-02-2011, 12:36 PM | #1 |
Need 1971 k10 rear cab mount specs
Hello,
i am working on a 71 k10 with rotted body mounts. i was able to find the "height" of the fwd mount from the assembly manual, but am unable to find the rear. my question is, with a straight edge across the frame how far down to the rear cab mounts sit? |
07-02-2011, 03:53 PM | #2 |
PROJECT 7DEUCE
Re: Need 1971 k10 rear cab mount specs
I'm not sure on the measurements but it seems to me like there should be some rivet hols where the old mounts where? BTW welcome to the board..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-02-2011, 05:08 PM | #3 |
The sides of the mounts are fine, its just top mounting pad has mostly rotted off. it appears that the rear mounts are aprox 1" down from the frame, i just need to know is the drop 1", 7/8" or 1 1/8. i would rather get that spec correct than shim later. thanks for the welcome.
