Accuair valve block question
I have all of my air system wired. Compressor and valves all work fine. However, the system won't build pressure because the air just bleeds out of the second "in" port. I am only using one compressor and one tank so this port is not used. Is it supposed to be plugged? If so, with what?
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
Re: Accuair valve block question
Wow...Reno at Accuair is FAST!! He already emailed me the answer. Thanks!
![]() Join Date: Feb 2008
yup....is that the answer?
There is a little plug that looks like a golf tee that goes into that port. It was in the box but I had no idea what it was for.
Tot Roddin'
Now that's service.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Reno rocks....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
