Old 07-02-2011, 05:27 PM   #1
1972RedNeck
1972RedNeck's Avatar
How Good Is My Air Conditioned Memory?
It is hot up here in Montana. 85 degrees. 83 degree heat index. My mind might be fried.
If my memory serves me correctly, there is a door inside the A/C box that diverts air to/away from the heater core? Is this correct? Is there any place to buy a new door/ A/C box? I know a door is broke and I repaired it with popsicle sticks/Gorilla Glue. I think this is leading to the air being not as cold as it should be. I have to run on inside air to shut the heater valve off because it blows hot air if I don’t. Any ideas? Suggestions?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-02-2011, 05:42 PM   #2
landsurvey1
landsurvey1's Avatar
Re: How Good Is My Air Conditioned Memory?
85 degrees, thats almost long john weather were I come from. It's going to be 117 in Phoenix today! Anyway, I put a valve in my heater hose, that way you can shut it off in summer and turn it on on winter.
landsurvey1 is offline   Reply With Quote
Old 07-02-2011, 05:53 PM   #3
1972RedNeck
I actually just put a ford valve in mine with a cable because as Jeff Foxworthy said "If you often switch from "heat" to "A/C" in the same day and back again, You might live in Montana."
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-02-2011, 05:57 PM   #4
BMERDOC
BMERDOC's Avatar
You are right about the blend door. I'm sure someone in China is stamping parts for it. The heater core should have a shut off valve already inline. Feel the hose on the intake side just past the valve. It should be cooler than before the valve. You may need a new valve because of improper sealing.
After you've fixed this get rid of your engine mounted fan and install an electric fan. Wire it so that it controls engine coolant temp AND comes on anytime you request A/C (do not wire it so it cylces with the compressor). Then wrap your dryer in insulation wrap. Replace the expansion valve (orifice tube?) and evacuate, vacuum and recharge it. You will be rewarded with snowballs coming from the center vent. This may be over the top now but its a good upgrade.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 07-02-2011, 06:09 PM   #5
1972RedNeck
I got rid of the clutch fan and now have a good ole' flex fan. I have a dual electric fan but the sound bugs me. I have put 4 different valves in and none have sealed. The ford valve works great. I should be able to have all the hot water in the world going through my heater core and not affect the A/C temp. The pipes going in and out of the condenser turn white with ice (I don't think the condenser is icing over). I have the right freon pressures also.
What should I wrap my dryer in? Does anyone know were I can get a blend door at?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-02-2011, 06:29 PM   #6
kcsa75
kcsa75's Avatar
I have one in the garage you can have for about $75 plus the ride. Of course you can save a lot of time by going down to your local Ford dealer.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 07-02-2011, 06:34 PM   #7
BMERDOC
BMERDOC's Avatar
LMC has something they call a air shut off valve. It is a door (pg 120). Probably would not hurt to reseal the box either (LMC pg 119). Wrap the dryer in camper tape. It comes on a roll and is insulated or use that asphalt based tape which would probably be better. Big Box DIY outlets will have something to insulate it.
Nick Carter
Old 07-02-2011, 06:39 PM   #8
1972RedNeck
I had the valve sitting on the shelf, got sick of Chinese crap, so I put U.S. parts on it
Is this what I need?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-02-2011, 06:44 PM   #9
BMERDOC
BMERDOC's Avatar
That is the portion of the system that controls outlet vent volume and direction (defrost, center, floor)
Nick Carter
Old 07-02-2011, 06:46 PM   #10
48richard
48richard's Avatar
Your truck should have a heater shut-off valve that is vacuum operated when you go to "Inside Air". I disconnected the vacuum hoses at the two air valves that change it over to inside air - one in the plenum and the other at the passenger side kick panel - and plugged the hoses. Now when I have the control set to inside air the heater water valve is closed, but I am still using outside air.
Makes a big difference in the cab, and in Phoenix I need all the help I can get.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 07-02-2011, 06:51 PM   #11
1972RedNeck
How much for the ride?
Would this be a potential problem?
Were can I get the door I need?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-02-2011, 06:55 PM   #12
BMERDOC
BMERDOC's Avatar
That looks like the same component I saw but looking at the pic again it looks like a fresh air vent to the cowl but if I remember correctly isn't the only fresh air from the kick panels?
Nick Carter
Old 07-02-2011, 09:25 PM   #13
1972RedNeck
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-02-2011, 09:43 PM   #14
sameyrasmea72
sameyrasmea72's Avatar
Where did you get that? I have looked at the parts stores for one that will replace the cacuum one and will keep the hot water out of the heater core.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 07-03-2011, 03:34 PM   #15
1972RedNeck
Bump
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-03-2011, 08:53 PM   #16
turp mcspray
turp mcspray's Avatar
Every vender sells the part you need. (air diverter box I think it's called) I just bought one for about $80. It is a gm piece.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
