07-02-2011, 08:02 PM | #1 |
Instrument Cluster
Just curious, is $20 a very good price for an instrument cluster? I know where one is for that price and have thought about buying it but haven't yet. Thanks!
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
07-02-2011, 08:13 PM | #2 |
Re: Instrument Cluster
i'd say yes. I bought a 60-63 cluster for $15 at a swap meet. and my truck is a 66.... So, yes, I think it's a good deal. I would make sure all the parts are there - and know what parts are replaceable (easily) - plastic if the $20 one's is cracked/beyond polishing out - needles ok - gauges work or not?, check to make sure odometer at least works, etc etc - don't expect it all to work, but once you know, you can make a decision. For $15, mine had all the parts. Not sure if ANY gauges work, but for $15 couldn't pass it up. Odometer and speedo worked though.
