Old 07-02-2011, 09:04 PM   #1
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Wink My Maiden Voyage
Well this evening was my first test drive since I bought my 1967 Chevy Suburban! Made the deal on Halloween 2010 and the transmission was not working. So in between work and other life events this was my first test drive since I owned the beast!
We put the transmission and transfer case in just after 5.5 hours of work. And it seemed like it fought us the entire time! Wasn't able to install the front drive shaft as the cap came off and lost all the needle bearing so will deal with that another day.
And WOW! I was a very hot day to be working under a truck!
But am I please it went well after some hick-ups. The drive was nice, but the brakes are very scary to say the least. My steering wheel doesn't line up correctly and my buddy said a front-end alignment will take care of that. Not very sure about that one. But it drive straight and shifts very smooth, so for the moment I am happy!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 07-02-2011, 09:24 PM   #2
o6r1man
o6r1man's Avatar
Re: My Maiden Voyage
Pics or it didn't happen Gongrats on the first drive!!!
1970 SWB "old flame"
1967 SWB c10 sold
1972 Elcamino 496
2012 Denali HD dmax
o6r1man is offline   Reply With Quote
Old 07-02-2011, 09:27 PM   #3
1972RedNeck
1972RedNeck's Avatar
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-02-2011, 09:31 PM   #4
o6r1man
o6r1man's Avatar
1967 SWB c10 sold
1972 Elcamino 496
2012 Denali HD dmax
Old 07-03-2011, 12:13 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Congrats on the 1st drive..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-03-2011, 09:02 PM   #6
C20-67_N_MO
Not much to post on pictures but I'll see what I can do for you guys.
Old 07-03-2011, 09:18 PM   #7
Sammy
3 months to KC. All trk nationals
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-03-2011, 09:41 PM   #8
C20-67_N_MO
Talking Re: My Maiden Voyage
Sammy,
I have a lot of little things to do before this thing is road worthy. Like for one I can't get my driver side window to roll down.
The regualtor seems like its stuck!
Might have to see if you can help with that if you have any ideas.
Old 07-04-2011, 07:33 AM   #9
Sammy
That doesn't bother me at all. I own a huge sludge hammer!!!!. I bet it can get thru the window. Usually it does do some raining that W/E any hoot. If you need help getting inside a door no problem. You have my cell..I have a few doctors type things every few days just call ahead of time to get stuff sliding around the days first. Glad you got the beast on it's own power..that is always a good sign to start with. Now get it to convince you it can be trusted for some adventure and to see your truck friends..
Old 07-04-2011, 07:39 AM   #10
Sammy
The door issue. Sounds like the regulator is FUBARRED with rusted out stuff. Pull the door panel inside the door and start with some spray lub or rust eatter and see what we have to work with. Let it sit for a day.. May need some cleaning out and see what can be salvaged to make it at least go up n down with some elbow grease.
Old 07-04-2011, 12:26 PM   #11
C20-67_N_MO
Sounds good.
I'll start by spraying it real good and let set for a day.
I have a spare regualtor so if I tear this one up its no big deal.
