![]() Join Date: Mar 2003
I have a turbo 400 on my truck and what is the procedure on how to change the trans filter and do I have to be careful on how tight I tighten the filter down?or do the bolts keep turning?and how do I change the kickdown solenoid? Thanks everyone.
Get ready to get dirty! remove all but two corner bolts on the pan, then start to losten them and get the pan to tip so the fluid "slowly" pours out. (haha) Buy a drain plug kit for next time and locate it on the passenger side of the pan so it doesn't interfere with trans linkage.
The filter should have a spacer (looks like a 1" piece of tubeing) between the filter and the valve body. The bolt should be snug but no need to get carried away with it. Good luck! ![]() |
