07-02-2011, 10:56 PM | #1 |
ECE Super Track Bar - BEND IT??
Has anyone ever had to bend a ECE super track bar to get it o fit around a rear end cover? I have a TA Girdle cover on my 12 bolt and the super track bar kit will not fit. Would it be OK to bend the bar to provide clearance? How would you do it?
"Love Affair" Build Thread |
07-03-2011, 12:12 AM | #2 |
Grandpa in the rustmobile...
Re: ECE Super Track Bar - BEND IT??
they sell a pre bent one i think..or swap to a stock cover.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-03-2011, 12:56 AM | #3 |
motor exploder
CPP makes a bent one also, I used it with my Moser diff cover, which is a TA casting. The CPP one has a pretty good bend in it, so I would think if you bent a straight bar to clear the cover, it probably wouldn't reach the track bar mount. I'm using a CPP bar and ECE mount on the trailing arm.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
07-03-2011, 12:58 AM | #4 |
~Rest In Peace~
what bar ?
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-03-2011, 01:07 AM | #5 |
motor exploder
^ haha bars? you've got 5 of them... here's mine, with the CPP bar.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 07-03-2011 at 01:12 AM. |
07-03-2011, 08:02 AM | #6 |
~Rest In Peace~
nice rear end cover there
07-03-2011, 01:04 PM | #7 |
fabrication and repositioning of panhard bar mounts is an oldschool type approach to a problem like that
07-03-2011, 02:12 PM | #8 |
motor exploder
I'm pretty sure 'Hart Rod' used an ECE atraight bar with a different mount to the trailing arm to remedy the same situation. He has pics in his build thread. The brackets he used came from Rob McGregor @ No Limit (a board vendor)
07-04-2011, 10:23 AM | #9 |
What do you do when your freshly purchased ECE Super Trac Bar doesn't fit around your also freshly purchased TA girdle diff cover? You get creative!!! A few cuts, tweaks, welds, and a little grinding later.... you make one that fits.
What do you think?
07-04-2011, 01:17 PM | #10 |
motor exploder
Looking at the pics, that turned out pretty good.
