Old 07-03-2011, 11:59 AM   #1
gotchamel
Heater hose/heater delete?
If I am not interested in having a working heater can heater hoses be removed and fittings plugged w/o affecting anything else?Currently there is no a/c.It would offer a cleaner looking engine bay.Thanks.
gotchamel is offline   Reply With Quote
Old 07-03-2011, 12:03 PM   #2
OldCreek
OldCreek's Avatar
Re: Heater hose/heater delete?
I once ran a 5/8" to 3/4" plastic adapter between the hoses when I removed the heater box...no problems that I could tell. I don't think plugging them would be an issue.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 07-03-2011, 12:06 PM   #3
gotchamel
My thoght is to plug the intake and wp with fittings and leave core fittings unattatched.
Old 07-03-2011, 01:53 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I used to work at a service station.....yeah it was a gas station where they had us young guys who came out to the car and pumped the gas while you sat in the seat. We'd clean windshields, check/air your tires, check your oil, transmission fluid, and tell you if you needed new wiper blades.
One of the extra things we got to do was deal with stuck thermostats and change light bulbs while you waited.
If you had a heater hose leaking, we'd take the larger hose, usually a 3/4-inch ID hose, and cut it to a shorter length, take the smaller diameter hose off, and attach the larger hose to the nipple...then tighten the hose clamp. I don't know if we ever did charge more that a dollar to do that for anyone. If you were a cute girl....it was usually free, so you could take it home and let your dad know we helped you out.....windshields were usually cleaned extra well for those girls, too.
Member Nr. 2770
Old 07-03-2011, 02:38 PM   #5
bosco200
bosco200's Avatar
My heater core started to leak, so now that its summer I wont be using it for a while so I did this.....
bosco200 is offline   Reply With Quote
Old 07-03-2011, 02:44 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you want it to look clean, remove the two bibs and install 1/2 npt plugs in their place to completely do away with the hoses all together.
Old 07-03-2011, 02:48 PM   #7
gotchamel
10-4,thats what I'm looking to achieve.A clean engine bay.I live in s.Florida,heater is not an issue.
Old 07-03-2011, 02:55 PM   #8
bosco200
bosco200's Avatar
O yea if your wanting it to look clean dont do what I did
Old 07-04-2011, 06:37 PM   #9
gotchamel
Put pipe plugs in both holes,looks tidy.Can't imagine needing heat right now.Thanks for the info guys.
