Old 07-03-2011, 02:16 PM   #1
Joe Chasse
Joe Chasse's Avatar
How to hot wire to start 76 HEI 350
How do I hotwire a 76 350 with hei ignition and no computer (no wiring AT ALL yet except new plugs and wires - dash panel is laying over on the shelf)? I have never owned one of these "modern" gizmos before. ALSO - just installed this 76 350/350 from a motor home and wonder how do I put the trans in park with no linkage? There's no driveline yet, but don't want that tailshaft spinning. joetruckATgmail.com
THANKS,
Joe
Joe Chasse is offline   Reply With Quote
Old 07-03-2011, 02:42 PM   #2
burb1085
burb1085's Avatar
Re: How to hot wire to start 76 HEI 350
Can't you just jump the starter solenoid? Your just trying to get the motor going right?
burb1085 is offline   Reply With Quote
Old 07-03-2011, 02:44 PM   #3
burb1085
burb1085's Avatar
You should also be able to turn the gear selector by hand to get it into park.
Old 07-03-2011, 02:48 PM   #4
J Knight
J Knight's Avatar
Why do you need to hot wire it, because there are different ways to do it depending on why.
To put trans in park rotate the lever on the left side counterclockwise till it stops.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 07-03-2011, 03:01 PM   #5
LONGHAIR
You would have to energize to distributor (coil) too, or it would just crank and not actually start. Simple enough, you just crimp a "female" spade connector onto a piece of wire that is long enough to reach from the positive side of the battery to the distributor. Plug it onto the "Batt" terminal of the distributor and clamp the other end to the battery.
"Jump" the starter and it will start/run disconnect it to stop the engine.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-03-2011, 07:43 PM   #6
Joe Chasse
Joe Chasse's Avatar
Thanks Longhair - THAT is what I needed to know. So far, all I have is a bunch of wires in looms from the donor truck which I drove in to the garage to pull the engine trans after wet/dry compression checks. I just want to see it run in it's new home a little bit before I spend the time/money/etc on exhaust, wiring, etc etc, you know what I mean...
Thanks again,
Joe
