Old 07-03-2011, 05:29 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Polyurethane bushings/mounts
I am replacing all my rubber suspension components, body mounts, trans, and motor mounts with polyurethane(PST) components. Is this a good or bad idea? Should i just do rubber?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 07-03-2011, 06:32 PM   #2
mooseknuckles
mooseknuckles's Avatar
Re: Polyurethane bushings/mounts
very good idea.....gets rid of the sloppy, worn out, rubber crap...just grease them up good!
mooseknuckles is offline   Reply With Quote
Old 07-03-2011, 10:40 PM   #3
bluex
bluex's Avatar
IMO dont do the engine and trans mounts. I put them on my old S10 and the vibration at idle was crazy. For a daily driver it was very annoying, esp with the A/C on....
bluex is offline   Reply With Quote
Old 07-04-2011, 02:21 PM   #4
lilpoindexter
lilpoindexter's Avatar
I think they belong in the sway bar bushings... anywhere else, I think they are overkill. New rubber is probably better,
lilpoindexter is offline   Reply With Quote
Old 07-05-2011, 04:58 AM   #5
DetroitDan
DetroitDan's Avatar
I replaced all my cab mounts with poly on one of the trucks I built, a 78 or 79. It stiffened the truck up considerably, was so harsh I hated it and replaced it with GM rubber after 2 weeks. When I took them back out one of the radiator support mounts was split nearly in two. Rubber makes it ride like a new truck, poly makes it feel like theres no suspension under you. And I'm not particularly picky about a smooth ride. So thumbs down from me.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 07-05-2011, 12:44 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Polygraphite bushings work great. I have them on my triuck. Strength of poly and softness of rubber! Use them you like them.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-05-2011, 02:35 PM   #7
Cherub
Cherub's Avatar
I have the Polygraphite bushings on my upper and lower control arms and swaybar. I dont think it can hurt.
Cherub is offline   Reply With Quote
Old 07-05-2011, 02:52 PM   #8
softballnrd27
I am going to go polygraphite on the suspension and new rubber mounts on the cab, trans and motor
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 07-06-2011, 02:37 AM   #9
bluex
bluex's Avatar
^^^ best idea IMO....
FYI energy suspension's black bushings are polygraphite as well. The red ones are just straight poly....
