Old 07-03-2011, 06:51 PM   #1
KMACD71
KMACD71's Avatar
Oil pressure gauge reads "off the chart"
I've decided to try to fix one of my nagging electrical issues. My oil gauge is one of them and for a while now it reads well past full when idling and the needle practically disappears when I hit the gas. I believe the problem started when changing my wiper motor or something under the dash. Is there a ground wire or something I may have knocked loose? The truck is a 71 with a 350 and has always run fine. Anyone experienced this before and know of a remedy. Thanks.
KMACD71 is offline   Reply With Quote
Old 07-03-2011, 07:20 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Oil pressure gauge reads "off the chart"
If it is the stock gauge, that is mechanical. You could try a stock 80# gauge if you can find one.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-04-2011, 06:43 AM   #3
That's right. The only thing electrical is the light in an oil pressure gauge. There's a fitting on the back of the block near the distributor with a small tube that runs into the gauge.
Old 07-04-2011, 11:28 AM   #4
StingRay
StingRay's Avatar
If you have a hi performance oil pump it'll pin the needle. An 80 PSI gauge from the C40-C60 trucks is just the ticket.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
