07-04-2011, 12:44 AM | #1 |
aftermarket oil pressure gauge leaking?
I bought me a set of gauges the other day and i put em on and my oil gauge is leaking out the back and i cant get the nut to tighten any farther up with out me being afraid of breaking it off any of you guys run into this problem?
1966 chevy 1/2 ton freshly rebuilt 350 stock cam performer intake 600 cfm edelbrock 4spd behind it 1986 chevy 4x4 1/2 ton 350 700r4/208 2in lift blocks 31 at tires |
07-04-2011, 12:57 AM | #2 |
Senior Enthusiast
Re: aftermarket oil pressure gauge leaking?
Assuming you’re talking about a mechanical gauge with either copper or nylon tubing, it sounds like the Ferrell is either missing or damaged. It slips over the tubing end after the compression nut, and crimps around the tubing causing the seal. Here’s a photo showing a pair in the center of the tubing coil.
http://www.summitracing.com/parts/ATM-3222/?rtype=10 |
07-04-2011, 04:43 AM | #3 |
A bit of teflon tape never hurts either.
if it has the plastic tubing ditch it for the copper at the very least or braided is preferred. |
07-04-2011, 10:22 AM | #4 |
this happen to me while driving down the road, hot oil squirting on my right leg. turns out the PO over torqued the nut and ruined the threads, had to replace the gauge.
The price of cool aint cheap. |
07-04-2011, 11:41 AM | #5 |
All the newer gages I am aware of use the nylon tubing and a ferrel that conforms and seals the first time it is tightened. IMO these work very good but are not foolproof. The ferrel is directional and can be installed on the tubing incorrectly. If the ferrel is installed backwards it will not seal correctly.Assuming it is pionting in the right direction,undo the line from the gage and look at the ferrel.You will see evidence of distortion where the ferrel is sealing against the gage.That distortion should be uniform around the ferrel. If any portion of that crimping is not correct,simply cut off the bad portion and redo with a new ferrel.
07-04-2011, 01:51 PM | #6 |
I 2nd the suugestion of removing plastic line if that's what it has. Use one of the copper line kits that are available through many/most local auto parts places.
07-04-2011, 02:06 PM | #7 | |
Senior Enthusiast
I used one of these two, I don’t remember which: http://www.summitracing.com/parts/ATM-3234/?rtype=10 http://www.summitracing.com/parts/ATM-3229/?rtype=10 |
07-05-2011, 02:09 PM | #8 |
ya im prob gonna upgrade here after awhile but right now im about out of money and just need it on the road i start my new job tomorrow and wont get paid for for 2 weeks =/ long time to stretch my last bit of money
07-05-2011, 02:18 PM | #9 |
Go to your local parts house and spend a couple of bucks getting a new ferrel fitting to stop the leak. You can upgrade later when funds are available.
I can't see the copper tubing with fittings costing more than about $10 bucks and it is far better than the plastic capillary tubing. |
07-05-2011, 09:40 PM | #10 |
i got it to stop leaking i put the ferral on the correct way turns out i was trying to just slide the tube in ive got it correctly installed now
07-05-2011, 11:54 PM | #11 | |
