Old 07-04-2011, 01:22 PM   #1
markeb01
Senior Enthusiast
markeb01's Avatar
Hood spring installation tip
Somebody has probably done this before, but I didn’t find much when looking for ideas. So here are photos of how I installed mine this morning when there wasn’t any assistance available. The first thing needed is a solid anchor to pull against. My “clean bench” is bolted to the wall studs on two levels, and the bench is assembled with bolts, so I knew it was up to the task.
I clamped a piece of steel tubing to the spring support projecting forward a few feet in front of the truck to assist in lining the truck up with the bench leg (sorry no picture). I parked the truck aiming the tubing just inboard of the bench leg, so the spring would not be dragged against anchor support.
I hooked the spring to the hinge arm, and used an industrial S hook on the other end to provide more flexibility to the ratchet strap hook. The ratchet strap pulled the spring into position, and a squeeze clamp was used to press it into the slot and hold it in position. Since the ratchet tension cannot be controlled when released, I simply drove the truck forward a couple of inches until the strap relaxed on the inner fender, and that was it.
I also used this technique to remove the springs. And by pre-drilling front and rear alignment holes in the hinge mounting plates, they were reinstalled in exactly the same location using two 1/8” pilot bits. As a result no adjustment is required and there are no scars on the hinges or the mounting bolts.
Here are photos showing the process and the finished assembly.
Old 07-04-2011, 01:30 PM   #2
jocko
jocko's Avatar
Re: Hood spring installation tip
hey Mark, engine compartment paint job looks great!! what did you use to pain it? Is that hammertone or krinkle paint, etc? I really like it.
And thanks for the idea of how to remove/install hood springs. Of course, I'd probably have actually shot a spring through the far side of the garage if I tried that, but I sure can't think of another way. Also like the "just drive the truck forward" to remove tension. I'd have scratched my head a little on that one.
Old 07-04-2011, 01:34 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
It's UPOL Raptor Bed Liner. A lot of people buy it from TP Tools. I was in a hurry so I bought mine locally and paid more for it. Make sure you get the kit complete with the gun. The threads are unique to UPOL bottles. I have a 3M Schutz gun but it won't screw onto the UPOL containers.
http://www.tptools.com/Product.aspx?display_id=2600
For whatever reason the Amazon link won't work this morning. They also sell it for $109.00
Old 07-04-2011, 01:36 PM   #4
Frizzle Fry
Frizzle Fry's Avatar
I like the washers between the coils trick. Seems safer too. Nice ingenuity though!
Frizzle Fry is offline   Reply With Quote
Old 07-04-2011, 01:36 PM   #5
JohnnyBoy350
I just spent 40 minuites fighting a prybar to get mine on. Scratches everything up. This is a great idea.
Oh and, that engine compartment looks awesome...great job!
-John
If it don't go, chrome it!
JohnnyBoy350 is offline   Reply With Quote
Old 07-04-2011, 01:37 PM   #6
steverino66
another great tip!
and your underhood paint job is outstanding (been following that on the "what did you do today" thread)
steverino66 is offline   Reply With Quote
Old 07-04-2011, 02:54 PM   #7
jocko
jocko's Avatar
Really? Bedliner? No kidding, I was gonna guess that at first, but it looks way too nice - while I can clearly see texture, I thought it was too smoothe for bedliner material - I better write this one down. jocko like.
Old 07-04-2011, 04:49 PM   #8
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
I have used wooden door wedges before to push the springs apart to get them to go on.....but never considered the method you just showed me ...Thats thinking ....goes to show you that if someone puts thier mind to doing something...they will find a way. Thanks for sharing
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 07-04-2011, 06:17 PM   #9
65Gregg
65Gregg's Avatar
Your engine compartment looks great!! I hook the rea spring hook into the hinge then use a piece of rope and pull on the front hook and stretch it to the attachement point. I remove them the same way.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 07-04-2011, 10:21 PM   #10
Bugeyev8
Bugeyev8's Avatar
you guys make way too big of a deal when installing the springs, I just put the front bolt on and the spring and then rotate the whole hinge back and install the rear bolt...no big deal
Bugeyev8 is offline   Reply With Quote
Old 07-04-2011, 10:30 PM   #11
TR65
TR65's Avatar
Here is another way to add to the mix. Similar to the tool the shop manual uses.
http://67-72chevytrucks.com/vboard/s...d.php?t=378660
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 07-04-2011, 10:48 PM   #12
wutnxt
bugeyev8
Ya i have used that method as well and it works great...but if everything is already powder coated or painted all nice the chance of a scratch goes up...
Old 07-04-2011, 10:59 PM   #13
Big Fenders
I used pennies to remove springs in a few projects Same as Frizzle Fry washers. So easy and easy to replace springs too.
Iv'e used vice grips a few times too....not as good as your set-up
Bob.
Big Fenders is offline   Reply With Quote
Old 07-05-2011, 12:09 AM   #14
Newold65
Hah I just did mine like fifteen minutes ago. Wish I would have read this or any of the other suggestions first. I grabbed a chain and pulled and then told a buddy to help out with the promise of "I'll try not to let go".
Newold65 is offline   Reply With Quote
Old 07-05-2011, 01:08 AM   #15
Captainfab
60-66 Nut
That's exactly how I've been doing them for 30+ years. If you have nice powder/paint on the inner fender, just cover the area with masking tape first, and then remove it once you have the hinge and spring loosely in place.
Old 07-30-2012, 02:37 AM   #16
Vernski
Some of you may be to young to remember what brake spring pliers are but they work great for me....Vernski
Vernski is offline   Reply With Quote
Old 07-30-2012, 05:38 AM   #17
T2vigil
T2vigil's Avatar
Vern, you'r telling your age. But sadly I too remember.
T2vigil is offline   Reply With Quote
Old 07-30-2012, 08:06 AM   #18
1963c-10
1963c-10's Avatar
Chevy actually made a tool for the job. Looks like a large comb, but Ive only seen pics of them.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-30-2012, 08:11 AM   #19
markeb01
Senior Enthusiast
markeb01's Avatar
Here's another thread showing a home made version of a device to hold the spring open:
http://67-72chevytrucks.com/vboard/s...spring+install
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-31-2012, 01:58 AM   #20
piratexpress1369a
piratexpress1369a's Avatar
funny i just did the same thing and same side in june ..lol
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 07-31-2012, 09:23 AM   #21
K98AL
K98AL's Avatar
My hood raises up in the back when closed -looks terrible. Do new hood springs generally fix this?
K98AL is offline   Reply With Quote
Old 07-31-2012, 11:00 AM   #22
markeb01
Senior Enthusiast
markeb01's Avatar
New springs won’t help. Your hinges are out of alignment and will need correction, shimming, or replacement depending on what’s wrong. Here are the factory instructions on how to align the hood:
Old 07-31-2012, 12:30 PM   #23
K98AL
K98AL's Avatar
thanks!
Old 07-31-2012, 12:45 PM   #24
ljackson
ljackson's Avatar
I used a similar set up. I pulled on the strap and had my son put the end of the spring in the slot.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 07-31-2012, 01:14 PM   #25
Chevy Fleetside
Chevy Fleetside's Avatar
That is how I do it also.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
