Old 07-04-2011, 03:47 PM   #1
1972RedNeck
1972RedNeck's Avatar
The Elusive Door.
Were can I get my hands on a new blend door for my A/C box. They seem to be nonexistent.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-04-2011, 03:59 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: The Elusive Door.
May try the parts board section..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-04-2011, 04:15 PM   #3
BMERDOC
BMERDOC's Avatar
Show us a pic of your popsicle repair. Show me a farther back shot of where the door is.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 07-04-2011, 07:52 PM   #4
1972RedNeck
I would except it is in the truck. I "fixed" it when I had the box out when I first got the truck 2 years ago. The A/C didn't work at the time and I didn't think the door would affect the temp. This is my daily driver so I would like to have the door before I tear into it for the third time.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-04-2011, 07:58 PM   #5
BMERDOC
BMERDOC's Avatar
I think the door we have discussed is your door. I just can't confirm it. The fresh air doors are vacuum operated on an a/c truck and hand op'd on heat cabs. The illustrations look like it would pull off the cowl but I think its a representaion of a vacuum operated door further inside the box.
Nick Carter
Old 07-04-2011, 11:13 PM   #6
turp mcspray
turp mcspray's Avatar
If you fixed a door with popsicle sticks, that would have to be the diverter box. I just bought one from the truck shop for $80. It is a gm part.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 07-05-2011, 01:03 PM   #7
1972RedNeck
So the heat did fry my memory!
Now that you say that I recall a little better the layout of my doors. Is the blend door the one in the firewall?
1966 F250 4X4 416
1972 K20 350 4 OTF
