Old 07-04-2011, 09:00 PM   #1
azjaeger
azjaeger's Avatar
Does anybody still make a mechanical oil pressure sender?
Been trolling around on Ebay and Google and I can't turn up a mechanical oil pressure sender for a 75 C20 with a 350. There's plenty with the electrical connectors, either for lights or gauges, and Rock Auto has something they SAY is 75 with gauge, but no picture...if anyone knows where to get one or a part # it would be appreciated. Thanks!
azjaeger is offline   Reply With Quote
Old 07-04-2011, 09:15 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Does anybody still make a mechanical oil pressure sender?
You can buy all the stuff at a hydraulic hose shop. The engine end is 1/8 npt. I usually just take the cluster into the hydraulic shop and tell them to make me a line that's "X" feet long to go from the gauge to the engine. 10 bucks or so and you're on the way.
Old 07-04-2011, 10:26 PM   #3
azjaeger
azjaeger's Avatar
Ah, thanks. Didn't think of that. I found where to get the line kit, but was coming up dry on the sender. Mucho gracias.
Old 07-04-2011, 11:28 PM   #4
jays68yak
jays68yak's Avatar
Thats because there is no "sender" for a mechanical oil gauge. Your just hooking up an oil line to the gauge from the motor basicly. No "sender" to give you false readings.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 07-05-2011, 11:33 PM   #5
azjaeger
azjaeger's Avatar
Yup. I guess I've just never had anything to do with mechanical oil gauges before so that didn't occur to me. Brain fart on my part. The truck had an engine swap at some point and they just left some of the old tube behind the dash and plugged the outlet on the new motor. Thanks again, this board is a lifesaver.
