ridiculous problem.please help.
Yup.the lower spindle ball joint.
on drivers side. the upper popped right out with a gentle smack of the hammer. i beat the $HIT out of the bottom with no success. so i got a balljoint splitter fork,ill just get a new ball joint(i have a 40 ton press) except ive beat the splitter in hard as possible with no luck,hasnt budged. with the fork in i hit the spindle.no luck now the fork is stuck in there. what in the hell do i do now? i cant fit a big sledge hammer in there,no clearence to swing.
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
Re: ridiculous problem.please help.
well your only bet is to hit it any direction to get things to vibrate and then free up or get the fork out and retry.
this truck will be the death of me
Still Just Havin Some Fun!
![]() Join Date: Jun 2007
I suffered the same issue not long ago. Then HartRod told me about a tool they use for this, so I ordered one and it sure made all the difference in the World. KENT MOORE J-23742 BALL JOINT SEPERATOR
a green one with some stuff done to it.... |
Use a blowtorch and heat up the balljoint after putting some cutting oil on it or something. You'll start to hear a tick, tick, tick after 45 secs or so. That's how you know it's finally broken loose. Wait for it to cool a bit, then smack it. It worked really well for my 41 year old balljoints.
thanks guys, ill try heatin up the joint with my small propane torch and wd-40 it and see what happens.if not,ill have to splurge and get the tool haha.
i appreciate the help ![]()
