Old 04-03-2003, 02:28 PM   #1
1969 GMC
1969 GMC's Avatar
idle getting faster
OK, I've had the GMC almost 3 months now, and I've noticed that the idle keeps going up. When I got the truck, it was around 700 rpm. then it went to about 1 grand. now its at 1100 or so. What's going on? I dunno much about Q-jets, or any carburetor for that matter. Any help appreciated
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-03-2003, 02:44 PM   #2
lpaine
lpaine's Avatar
Could be sticky gummed up linkages or your return spring just needs replacing. Spray on some carb cleaner to free up any linkages. Return springs are easy to find and fix, but don't put a really heavy spring on there, too much tension will wear the heck out of the throttle shaft bushings, (if they are'nt worn already). Your carb is just probably dirty, you did'nt say if the carb was rebuilt at any time but I'm assuming it's probably not been. Anyway, try the simple things first, I always say. Hope this helps.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 04-03-2003, 05:59 PM   #3
sakohntr
sakohntr's Avatar
vacuum
Could also be a vacuum leak getting worse. Love those quadrajets...
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
