07-05-2011, 06:15 PM | #1 |
alternator bracket?
so i found out that when you put a edelbrock performer intake on and a new long water pump that the passenger side style bracket no longer fits anybody else have this problem i may have to move it back to the older ones on the driver side
1966 chevy 1/2 ton freshly rebuilt 350 stock cam performer intake 600 cfm edelbrock 4spd behind it 1986 chevy 4x4 1/2 ton 350 700r4/208 2in lift blocks 31 at tires |
07-05-2011, 07:12 PM | #2 |
Senior Enthusiast
Re: alternator bracket?
I don’t know if I had the same type alternator bracket, but I ran an Edelbrock intake/long water pump setup years ago when I first put my truck together. Looking at an old photo, as best I remember I just modified the bolt hole in the bracket into a slot by cutting out the center of the bracket hole. Rather than a circle it ended up a U shape, allowing fore and aft adjustment. I clamped it with a washer large enough to cover the gap and it worked fine for many years until I installed A/C and swapped to Alan Grove brackets.
07-06-2011, 12:45 AM | #3 |
60-66 Nut
I have also had to modify the upper alt bracket to fit the Performer intake. I don't know why it isn't in the correct location. Edelbrock typically does a good job assuring fitment of factory parts.
07-06-2011, 10:36 AM | #4 |
I had this problem on my 69 Chevelle with 350 and Perfomer intake. The car now has a big block, but if I remember correctly, I got an upper alternator bracket from a mid-80's Caprice that attached at a different location, and everything fit nicely.
07-06-2011, 10:42 AM | #5 |
What do you know, I got lucky and found an old photo. 350 with Performer RPM, passenger side alternator, and mid-80's Caprice bracket...
