driver side leaning hard?2WD
What could cause the driver side on my '67 2wd to lean like 1 1/2-2" lower then the passenger side?
tires has exact same pressure and heighth and on level ground. ball joints? control arm bushings? i have a mess.
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
Re: driver side leaning hard?2WD
probably a bad spring
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
not uncommon with 40years of use and abuse
well you guys were definately right....Removed drivers side spring.
It broke about 2 coils off the top of the spring. im gonna be cutting these anyways to lower it a bit,is it okay to cut from the top? i seen its a smaller coil at the very top...
