Old 07-05-2011, 07:28 PM   #1
FickleFinn
1987 parts to 1967 & 1972
I picked up the '87 r10 cheap and will use the parts in both my 1967 pickup and my grandson's 1972.
My grandson just picked up a very original 1972 C20 (96,000 original miles with original paint) with new Motor/Tranny (350 carb and th350 tranny) with a bunch of other quality parts installed - new radiator, shocks (air in back) new tires (Michelin) and a bunch of cleanup done.
I think a lot of parts from the 1987 will fit 1972 - the heater&A/C, Seat etc. anything I should watch out for?
I will use the motor/tranny (350 tbi and 700r4) in my 1967 Chevy Stepside. From what I have read I can use the harness from the 1987 on my '67 with minor mods. Does anyone have a wiring diagram that shows how to do this? Would it be easier to take the entire harness (inside and outside form the 1987 and put it into the 1967??
Thx,
Mike
FickleFinn is offline   Reply With Quote
Old 07-05-2011, 10:15 PM   #2
sean1969c10
sean1969c10's Avatar
Re: 1987 parts to 1967 & 1972
The TBI wiring harness is mostly isolated on an 87 truck. It would be pretty easy to take the computer, harness and pump relay and install it on a older truck. Don't forget to grab the power steering and the disc brakes from the R series .
Sean
"If your gonna be dumb, you gotta be tough"
1960 Chevy Impala Sedan - my 25 year search is over!!
1969 C-10 longbed - Nice day DD
1970 Chevy Nova - Street and Strip Project
2002 Acura MDX my DD
2007 Honda Odssey - My Wife's "Mommy Van"
sean1969c10 is offline   Reply With Quote
Old 07-05-2011, 11:16 PM   #3
FickleFinn
Thanks Sean, My '67 already has PS and PB (drums), I may grab the disks to have them for the future.
Any thoughts on the heater etc fitting the '72?
Thx,
Mike
Old 07-06-2011, 06:32 AM   #4
sean1969c10
I'm not sure about the heater. The boxes are totally different shapes.
Sean
Old 07-06-2011, 11:10 AM   #5
KrazyRay
KrazyRay's Avatar
You are better off finding the period correct heater to use in your 67. I part out a bunch of 67-72 and a bunch of 73-87 trucks and I think it would be a nightmare to put an 87 heater in a 67 IMHO.
KrazyRay is offline   Reply With Quote
Old 07-06-2011, 02:57 PM   #6
Mister laugh
As far as harnesses go if you are going through the trouble to repalcing the whole harness just use a new one. No point in going through the nightmare of trying to make a 24 year old harness that has likely been mangled by previous owners and aged fit into a 44 year old truck. New harnesses didn't cost that much last time i looked into it.
Mister laugh is offline   Reply With Quote
Old 07-21-2011, 07:42 PM   #7
FickleFinn
Just back from 2 weeks fishin with the grandson's so a bit late in responding!
Thanks for the feedback on the heater, I had also thought of putting the heater in my grandson's 1972 C10, but sounds like it is the same as my '67. Wanted to give him A/C.
Mister laugh - so you would buy a 1987 harness and convert make it fit the '67?
I also need a 12bolt 6 lug rear-end for my '67, would like 3.73 with posi - know of 1 near Vacaville??
Old 07-24-2011, 01:57 AM   #8
FickleFinn
Would the saddle tanks from the '87 fit under the '72? Then we could remove the tank from behind the seat.
I assume I would have to change the fuel delivery as the tanks have fuel pumps inside them.
Thx,
Mike
Old 07-24-2011, 01:58 AM   #9
FickleFinn
ps. I found the rear end! Picking it up tomorrow - 12 bolt, 6 lub, 3.73, but no Posi. complete with backing plates, emergency brake cables etc.
Old 11-24-2011, 02:12 AM   #10
FickleFinn
Just started the teardown of the '87, front clip if off, the interior wiring is out and the engine wiring is on top of the motor, left everything hooked up as much as possible to keep track. pulled the computer.
There was another box by the steering column, what is it?
Can I take the air pump and all that stuff off the '87 when I put it into the '67? How does it affect the O2 sensor?
What about all the other things like charcoal filter etc, can I leave them off?
Thx in advance
Make it a great day!
Mike
Old 11-24-2011, 10:28 AM   #11
gcburdic
Restoration Virgin!
gcburdic's Avatar
You can remove the complete front suspension x-member and swap it into the 67...I think you'll have to drill a couple more holes in the frame, but you get the disc brakes!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
