07-05-2011, 09:36 PM | #1 |
Fuel line options
I'm relocating my tank to the rear. I didn't really plan ahead and now I'm stuck. The rear of my frame is notched, boxed around the notch and has a custom crossmember to mount the shocks right in front of the notch. This is my first time running fuel line and I'm having a hard time routing the fuel line around all that. I've been trying to use 3/8" steel line. Any bend over about 45 degrees is trying to crimp the line (using the nicest bender that autozone rents out). I'm pretty frustrated at this point. Can I use some kind of flexible line from the tank to in front of the notch and then hard line to the front? If I could make it work with two pieces of hard line, now would I mate them together. I'm new to this. Thanks.
BRENT -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
07-05-2011, 09:41 PM | #2 |
Cruzin
Re: Fuel line options
i don't see why not use some rubber as long as it's protected from sharp edges. Just like the factory lines is a piece of rubber from tank to frame and frame to pump. I'm just proud your gonna use mostly steel line for the price its much better than some i've seen that run rubber everywhere
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
07-05-2011, 09:41 PM | #3 |
I used steel braided for the whole thing. Summit sells a kit with all of the fittings for pretty reasonable.
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
07-05-2011, 09:48 PM | #4 |
its all about the +6 inches
I would get a better bender
07-05-2011, 11:34 PM | #5 |
