Old 04-03-2003, 03:42 PM   #1
BaggedC10
Under construction!
BaggedC10's Avatar
Red face Another cab mount and fuel question!
I removed the 4 cab mount bolts and the cab is still tight. Do I need to remove the front radiator support mounts as well? FYI, the fenders and etc. are bolted up and I haven't touched anything up front.
I need a picture of the factory hard crossover fuel lines installed. Also, I need the fuel clips to secure the three of them together. Where can I find them? I'm having trouble putting them together and having the ends sit properly.
Thanks in advance.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 04-03-2003, 03:43 PM   #2
TIMSPEED
TIMSPEED's Avatar
Just buy a fuel Cell and run Steel Braided line from it to the carb
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 04-03-2003, 03:49 PM   #3
gldevall
gldevall's Avatar
LMC would probably be your best be on this.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 04-03-2003, 03:50 PM   #4
BaggedC10
Under construction!
BaggedC10's Avatar
That was my plan for a while, but I spent a few hundred dollars "restoring" my factory tanks.
Old 04-03-2003, 04:28 PM   #5
BaggedC10
Under construction!
BaggedC10's Avatar
Another question: My PST body mounts are 1-piece, but the factory ones are two pieces. Am I supposed to cut the PST ones in half? There is a line down the center of them.
Old 04-03-2003, 04:44 PM   #6
TIMSPEED
TIMSPEED's Avatar
The PST's should be both of the factory pieces combined. (hence the line in the middle) They're the same width as the 2 factory ones, right??
See Them Here
Old 04-03-2003, 04:52 PM   #7
BaggedC10
Under construction!
BaggedC10's Avatar
Yep, they are combined. The PST ones are the same width and a bit higher. I'll have to cut them down that line---What should I use for a clean cut? I know Chris said he used PST mounts on his truck. Hopefully, he'll see this and chime in.
Old 04-03-2003, 06:10 PM   #8
BaggedC10
Under construction!
BaggedC10's Avatar
TTT
Old 04-03-2003, 08:06 PM   #9
BaggedC10
Under construction!
BaggedC10's Avatar
Anyone?
Old 04-03-2003, 08:11 PM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You shouldn't have to cut the bushings. They should be seperated already and have 12 in a package. Are you sure you have the right part number?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-03-2003, 08:22 PM   #11
BaggedC10
Under construction!
BaggedC10's Avatar
Hmm............Not sure if this is the PN or not---3.4116G? I'll have to give them a call tomorrow.
Now, why isn't my cab lifting up?
Old 04-03-2003, 08:44 PM   #12
Ol' Grey
A work in progress
Ol' Grey's Avatar
Re: Another cab mount and fuel question!
There are 6 mounts. Two in back, two in middle, and two at the front of the frame.
Marc Cook
1986 Chevy Silverado C-10 LWB
Gunmetal Grey Metallic
5.0L HO, 700-R4, '73 12-bolt rear
Long tube headers, 2.5" dual exhaust dumped before the axle.
1988 GMC Sierra SLE 4WD
5.7L, 700-R4, stock everything
6000LB winch
Ol' Grey is offline   Reply With Quote
Old 04-03-2003, 08:55 PM   #13
BaggedC10
Under construction!
BaggedC10's Avatar
Re: Re: Another cab mount and fuel question!
Okay, then I do have to remove the radiator support mounts as well. I'll keep you guys' updated on my situation with PST.
Old 04-03-2003, 09:08 PM   #14
swervin ervin
You get what you pay for
swervin ervin's Avatar
Stupid question I know, but what are you using to try and lift it?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 04-03-2003, 09:25 PM   #15
BaggedC10
Under construction!
BaggedC10's Avatar
A floor jack and 2x4. I'll remove the front mounts and see if that does the trick.
Old 04-04-2003, 12:11 AM   #16
Captkaos
Captkaos's Avatar
I wouldn't "remove" them. I would take one side completely out, and losen the opposite side. And yes you need to losen all of them.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
