Old 07-06-2011, 12:50 PM   #1
FL71C10
Upper Ball Joints
I'm replacing my balljoints. Do I install the bolts for the upper ones with the nuts facing up, or down? Or does it matter?
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 07-06-2011, 01:20 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Upper Ball Joints
Hey John, my nuts are on the bottom (when there not in a vice!)
Brad
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 07-06-2011, 01:22 PM   #3
Indyuke
I thought the nuts when up, bolt heads went down.
Indyuke is offline   Reply With Quote
Old 07-06-2011, 01:23 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I don't think it really makes any difference, but how they're assembled at the factory is based on what is easiest for the man on the assembly line....and defined by some engineers who did a time study for efficiency.
Since it is in your control, you can do it however you want to do it. Me, I'm just gonna stick the bolts in the top (cleaner look) and put the nuts on the bottom. Nuts usually hang lower......
Member Nr. 2770
Old 07-06-2011, 01:46 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Nuts go on top. Otherwise the threaded end of the bolt can gouge the rubber boot when the ball joint is greased and the boot bulges out. That's from Moog's instructions in the box.
Old 07-06-2011, 01:57 PM   #6
Shane
Shane's Avatar
Originally Posted by tx firefighter View Post
nuts go on top. Otherwise the threaded end of the bolt can gouge the rubber boot when the ball joint is greased and the boot bulges out. That's from moog's instructions in the box.
x2
Shane is offline   Reply With Quote
Old 07-06-2011, 04:14 PM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
x3
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-06-2011, 10:06 PM   #8
hayhauler71
hayhauler71's Avatar
nuts on top i have seen where people have put nuts on bottom and the bolts are to long and rub on the steering knuckle and this can cause binding and sometimes failure of bolts
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 07-06-2011, 11:37 PM   #9
1968CHEVYC10
1968CHEVYC10's Avatar
Yep I found a few threads when I replaced mine a few months back, and all had the same verdict, nuts on top, and that's what the instructions said.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 07-06-2011, 11:40 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Well, I'm glad you guys told us how to do it. I'm sure I would have seen it in my instructions (Moog), but I showed y'all that I didn't know the right way. Now, I do. THANKS!!!!
Member Nr. 2770
Old 07-06-2011, 11:51 PM   #11
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
dang should've read the instructions i did nuts down duuhh
John
1999 Toyota Tacoma 4x4
Old 07-07-2011, 06:47 AM   #12
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Add me to the nuts on top list.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
