Old 07-06-2011, 02:07 PM   #1
BIG D 85 gmc
Radiator help
need to c if a 83 c20 would fit on a 68 c10
BIG D 85 gmc is offline   Reply With Quote
Old 07-06-2011, 03:03 PM   #2
bosco200
bosco200's Avatar
Re: Radiator help
Im pretty sure the way it mounts will be diffrent but im not 100% sure.
bosco200 is offline   Reply With Quote
Old 07-06-2011, 05:50 PM   #3
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Re: Radiator help
My 68 had one from a later model truck. they used the top panel from the donor truck instead of the 68 radiator hold downs. wasn't quite right, but it was a radiator.
specialtyretail is offline   Reply With Quote
Old 07-06-2011, 07:39 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Radiator help
the 73 - 87 trucks had a short rad or a tall one, the core its self was taller on some. If the one you are looking at is the same core height as the one you need, then you're in the door. You'll then need to cut the upturned lower hose neck off the old rad and have it put on the replacement rad (go to a radiator shop for this, won't cost much) and then it'll drop right in. If you have an automatic, the lines won't reach properly, I can't remember if you can make them fit or if you'll need to make extentions.
Old 07-07-2011, 07:53 AM   #5
MARKDTN
Re: Radiator help
What he said, but I think you can also use the lower radiator hose from the donor truck application.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-07-2011, 11:06 PM   #6
Longhorn Man
Re: Radiator help
I've heard of that being done, but i don't see how. The frame curves up just aft of the rad, a straight neck would put the hose on the frame.
