Old 04-03-2003, 04:36 PM   #1
northeastblazer
motor and tranny options
What motors, transmissions, and t-cases were available for the:
69 Blazer 4x4
70 Blazer 4x4
71 Blazer 4x4
72 Blazer 4x4
Thanks.
Looking for a 69-72 Blazer...
northeastblazer is offline   Reply With Quote
Old 04-03-2003, 04:47 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Info for all years unless specifically noted
Engines:
250 six, 307 v8, 350 v8, maybe 292 six.
No big blocks ever factory produced
Trannys:
3 speed manual column shift
4 speed floor shift with granny low
3 Speed automatics 70-72 only
Xfer cases:
Np205 in 70-72 for all trannys except 3 speed manual
Dana's were put behind the 3 speed manuals
In 69, I know trucks had the Rockwell, not sure of Blazers.
I'm sure you'll get other feedback that may contradict this buit thats part of the fun.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-03-2003, 05:30 PM   #3
1969 GMC
1969 GMC's Avatar
Check out this link, it should help
http://www.coloradok5.com/specs.shtml
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-03-2003, 07:09 PM   #4
northeastblazer
Thanks, that link is great.
Old 04-03-2003, 09:05 PM   #5
mrein3
mrein3's Avatar
CPNE - Good call. I had a 3-speed manual in my truck in front of a NP205 before I made it a TH350/NP205. I sold the tranny to a board member in Iowa who was intending to put it in his 67-72 that came from the factory with a 3-speed/NP205.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-03-2003, 09:22 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
Now that you mention it I parted a 72 1/2 ton 4x4 that had a 3 speed manual with an NP205, yet the 71 chassis overhaul manual clearly shows the dana 20 xfer case so it was definately used. Only for Blazer applications from what I was told.
mrein3, is your example from a truck or Blazer?
Old 04-04-2003, 09:50 AM   #7
mrein3
mrein3's Avatar
The truck it came in originally was a 1971 K10.
'72 Malibu hard top
Center City, MN
