Crossmember identification and question?
Hey guys I have been trying to find something on here about the crossmembers being almost universal in that on some trucks the crossmember was the same wether it was leafs or trailing arms. Is this correct?? Thanks in advance.
Here is a pic of mine ![]() ![]() Posted via Mobile Device |
Re: Crossmember identification and question?
Forgot to mention its a 1970 lwb c10... thanks.
It looks like you are referring to the crossmember that is in the middle and it would react the trailing arms on a truck that has coil springs. From what I have seen the cross members are the same on the 2 wd whether coil or leaf springs. My son's original 69 GMC with leaf springs had the crossmember on it with the trailing arm brackets riveted to it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Ok cause that's what im trying to figure out ...if with this crossmember I can convert to the trailing arms by installing the arm mounts and cutting the spring pads off and getting it mocked up and welded it in and install adjustable trac bar?
