Old 07-06-2011, 09:00 PM   #1
krazy_texan
krazy_texan's Avatar
Ford rearend in a 65 c10
Just wondering if anybody has put a ford 9 inch or even an 8.8 rearend in these trucks and how hard or labor intensive it is and is it worth it if I am building it to be a weekend toy/ daily driver
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 07-07-2011, 12:25 AM   #2
Captainfab
60-66 Nut
Re: Ford rearend in a 65 c10
Here's one build with an 8.8
http://www.67-72chevytrucks.com/vboa...d.php?t=385486
IMO there's nothing wrong with the truck 12 bolt for your intended use.
Old 07-07-2011, 01:06 AM   #3
TopFuel1966
TopFuel1966's Avatar
Ford 9" is not a problem. You can narrow it or look for one that is the same width as your stocker. You can get mounting pads from someone like ECE.
TopFuel1966 is offline   Reply With Quote
Old 07-07-2011, 02:32 AM   #4
Joemomma1
Joemomma1's Avatar
Im running an 8.8 and it fits perfectly. Disk brakes, limited slip and was 61" wms to wms. All that was needed was the u bolt perches welded in. A 12 bolt would work fine too but I used what I had.
Joemomma1 is offline   Reply With Quote
Old 07-07-2011, 11:19 AM   #5
vin63
It's Better With Nitro
vin63's Avatar
As mentioned, a Ford 9-inch is no problem. I had an extra sheetmetal housing laying around for my build, but the concept is the same.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-07-2011, 01:10 PM   #6
krazy_texan
Ya I do agree with the fact that there is nothing wrong with a 12 bolt but I just happened across a couple of good nine inchers for really cheap and my 12 bolt is trashed unless I want to spend a load of money on it
Krazy Texan
1990 v1500 suburban
