07-06-2011, 09:02 PM | #1 |
e brake
I have a 66 k10 and it has been sitting for four yrs. My question is the e-brake doesnt work, were should I start? The truck is running driving, the brakes work otherwise.
07-06-2011, 09:50 PM | #2 |
Re: e brake
i'd check the integrity of all the cables and for any missing anchors (i.e. like the metal bar that hoks around the cable and then anchorst to the frame - kind of under where the passenger's left foot would be, if that makes sense - that piece seems to be an easy one to go missing.... other than that, you will probably have to bust into the rear drums and make sure the ebrake levers are making the shoes engage the drum.
07-06-2011, 10:02 PM | #3 |
Re: e brake
amccomb:
If all of the parts are there, I would check for rusty cables. The ones in the back that go through the backing plates to the rear brake drums tend to rust solid in their sheaths from lack of use. That would be the first place I would check. Regards, Steve New Orleans |
07-09-2011, 06:24 PM | #4 |
Re: e brake
Thanks guys!!
07-09-2011, 07:43 PM | #5 |
Who Me?
Re: e brake
Post some pics, that way we can see whats going on there.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
07-09-2011, 10:59 PM | #6 |
Re: e brake
I plan on messing with it tom. ill see what i can do.
07-09-2011, 11:29 PM | #7 |
Re: e brake
e-brake setup changed in 1966 from the previous model years... on the half tons, 2wds.
Not sure if there was a big difference or not on the 4x4s. e-brake pics and other information... 1966 and later setup That should get you pointed in the right direction. -W |
07-12-2011, 12:05 AM | #8 |
Re: e brake
I need a new front brake cable that attaches to the handle. where is the best place to get one? Is there any difference in cables between 2wd and 4wd?
07-12-2011, 08:32 AM | #9 |
Re: e brake
amccomb:
I used inlinetube.com. They made exactly what I needed to order. Price was reasonable and response time was fast. Regards, Steve http://inlinetube.com/ |
07-13-2011, 02:47 PM | #10 |
Easy Does It
Re: e brake
classicparts.com thats where I bought mine ,they have all of them
07-13-2011, 06:08 PM | #11 |
Re: e brake
Thanks for the info guys its a big help!!
07-18-2011, 11:08 AM | #12 |
Re: e brake
Thanks for the help i just ordered a new front cable from inlinetube. Should solve my problem.
